[Qgis-developer] Layer Visibility and Transparency
Peter Ersts
ersts at amnh.org
Fri Oct 23 10:17:37 EDT 2009
Sergio,
After either of these steps you would have to refresh the map canvas to
see the changes, which would will mean redrawing all of the visible layers.
I don't know exactly how you are trying to implement this, but your best
approach may be render each layer as an image ( "off screen" ) then have
your application/plugin cycle through these images instead of using the
map canvas, if that is what you are doing.
The transparency block looks fine at first glance ( you can use
qgsrasterlayerproperties.cpp as an example if you have not already ) but
take in mind you have to apply that to _each_ raster layer after it has
been initialized.
-pete
sergio cavalcante wrote:
> Hello guys,
> I'm developing a tool using the great qgis api, but i've got some
> problems to use some features, and after search a lot, I need your
> help. That are two issues.
> 1 - I need to make an animation mode for raster images. So first, I've
> tried to make a list with all raster images, and, using a QTimeLine,
> set them visible or not. but the comand
> QgsMapCanvasLayer(LayerSet.at(0)).SetVisible(FALSE); //Layerset is the
> MapCanvas LayerSet.
> it didin't work. So, to make the animation possible, I've had to
> replace the current layerset of the mapcanvas, but this is too memory
> expensive. So why possibly this setVisible didn't work?
> 2 - I need to make a pixel color transparent. I've achieved that using
> the setNoDataValue, but what I really need is, instead of make the
> pixel completely transparent, a transparency of, for example 50%. I've
> also tried with this function:
> QgsRasterTransparency::TransparentSingleValuePixel myTransparentPixel;
> QList<QgsRasterTransparency::TransparentSingleValuePixel>
> myTransparentSingleValuePixelList;
> myTransparentPixel.pixelValue = 0.0;
> myTransparentPixel.percentTransparent = 50.0;
> myTransparentSingleValuePixelList.append( myTransparentPixel );
> mRasterLayer->rasterTransparency()->setTransparentSingleValuePixelList(
> myTransparentSingleValuePixelList );
> m_qgsImage->refresh();
> but, it also didn't work.
> Any Ideas?
> Best Regards,
> Sérgio Cavalcante
Peter J. Ersts, Software Developer
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Web: http://biodiversityinformatics.amnh.org
Web: http://cbc.amnh.org
Open Source,
...evolving through community cooperation to change the world bit by bit
Quantum GIS Raster Development Team.
