[Qgis-developer] qgscomposermap.sip compile error
William Kyngesburye
woklist at kyngchaos.com
Mon Oct 26 11:38:57 EDT 2009
That works, no errors.
On Oct 26, 2009, at 10:17 AM, Marco Hugentobler wrote:
> Hi William
> Hm, that does not happen here. Is the compile error still there
> after r11850?
> If yes, on which line?
> Regards,
> Marco
> Am Montag, 26. Oktober 2009 14.57:48 schrieb William Kyngesburye:
>> Looks like a problem with the new rotate composer map feature.
>> Syntax
>> error at line 166.
>> SIP 4.8.2
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do if
you ARE a maniacally depressed robot? No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
