[Qgis-developer] Re: [Qgis-user] QGIS Image Clipper Plugin Available
Agustin Lobo
alobolistas at gmail.com
Wed Sep 2 03:46:31 EDT 2009
Bruce,
Hopefully you'll find help among the developers,
this is really a critical missing utility in QGIS.
Agus
Bruce, Bob (CON) wrote:
> Agustin:
> I have not seen any of these errors in the Windows
> version of QGIS. It must be related to a difference between the two
> systems. I only have one Linux system and it is CENTOS and I haven't
> been able to build QGIS there yet.
> It may be possible to have an option to draw a circle (or
> perhaps cross-hairs) after the draw is done at the coordinates that are
> entered, I will check into this.
> Bob
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Agustin Lobo
> Sent: Tuesday, September 01, 2009 3:29 AM
> To: Bob Bruce
> Cc: QGIS User List
> Subject: Re: [Qgis-user] QGIS Image Clipper Plugin Available
> Very interested on both, many thanks for your
> contribution.
> I've tested on ubuntu jaunty with unstable qgis 1.2.0:
> 1.Image clipping (should not be named raster clipping?):
> Once I click "Clip the Image": I get:
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File
> "/home/alobo/.qgis//python/plugins/image_clipper/dlgimageclipper.py",
> line 228, in ClipImage
> gdal_merge(gdalstring)
> File
> "/home/alobo/.qgis//python/plugins/image_clipper/gdal_merge_bb.py", line
> 467, in gdal_merge
> fi.copy_into( t_fh, band, band, nodata )
> File
> 241, in copy_into
> nodata_arg )
> File
> 48, in raster_copy
> nodata )
> File
> 84, in raster_copy_with_nodata
> t_xsize, t_ysize )
> File "/usr/lib/python2.5/site-packages/osgeo/gdal.py", line 831, in
> ReadAsArray
> import gdalnumeric
> File "/usr/lib/python2.5/site-packages/osgeo/gdalnumeric.py", line 1,
> in
> from gdal_array import *
> File "/usr/lib/python2.5/site-packages/osgeo/gdal_array.py", line 7,
> in
> import _gdal_array
> ImportError: dynamic module does not define init function
> (init_gdal_array)
> 2. zoom-to-point plugin
> After installation, I get the same message as reported by Giovanni
> (just tried 09/1 10:22 am GMT+2)
> "The plugin seems to have been installed but I don't know where...."
> But the directory gets to its right place ant the plugin works.
> Just a suggestion: Could you add (optionally) a circle around the point?
> Even if it is the
> central point, sometimes you want to make sure it's around the feature
> you want.
> Agus
> Bob Bruce wrote:
>> Hi:
>> I have a plugin available that people may be interested in
>> testing. This can be used to extract and combine portions of one or
>> more image layers in QGIS. I have only used this on Windows but
>> hopefully it would work OK in Linux also. You can get it and some test
>> data by going to the page:
>> http://www.mappinggeek.ca/QGISPythonPlugins/Bobs-QGIS-plugins.xml . We
>> have been using this plugin a lot at my workplace to extract the
>> useable portions of scanned photography that we have georeferenced
>> using the GDAL Georeferencer plugin.
>> There is also the zoom-to-point plugin that I have tweaked to work
>> better with zoom levels.
>> Bob Bruce
>> No virus found in this outgoing message.
>> Checked by AVG - www.avg.com
>> Version: 8.5.409 / Virus Database: 270.13.71/2335 - Release Date:
> 08/30/09 06:36:00
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090902/2b0f190f/alobolistas.vcf
