[Qgis-developer] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not
work]
Agustin Lobo
alobolistas at gmail.com
Fri Sep 11 06:17:04 EDT 2009
Follow up: using
sudo apt-get install qgis-plugin-grass
instead of Synaptic and having libgdal1-1.6.0 previously
installed (and not having libgdal1-1.5.0),
does not install libgdal1-1.5.0, but QGIS still crashes with the same
message
Agus
-------- Original Message --------
Subject: Binary QGIS 1.2.0.2~jaunty + GRASS does not work
Date: Fri, 11 Sep 2009 11:56:33 +0200
Reply-To: Agustin.Lobo at ija.csic.es
To: qgis-user <qgis-user at lists.osgeo.org>, qgis-developer
<qgis-developer at lists.osgeo.org>
After upgrading to QGIS 1.2.0.2~jaunty, the python grass
plugin still installs libgdal1-1.5.0 (+ grass 6.4.0~rc5-2~jaunty)
and QGIS crashes upon start up with message:
"Uncatched fatal GRASS error. Incompatible library version for module.
You need to rebuild GRASS or untangle multiple installations"
Removing libgdal1-1.6.0 does not solve the problem
Removing libgdal1-1.5.0 (now you can do it without automatic uninstal
of the grass plugin) and installing libgdal1-1.6.0 does not solve the
problem either.
Grass runs fine independently in all cases.
Qgis runs fine without the grass plugin
Agus
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090911/78296493/alobolistas.vcf
