[Qgis-developer] Re: [Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not work]
Jürgen E. Fischer jef at norbit.de
Fri Sep 11 11:35:46 EDT 2009
Hi Rainer,
On Fri, 11. Sep 2009 at 15:38:11 +0200, Rainer M Krug wrote:
> rkrug at ecolmod:~$ gdalinfo --version
> GDAL 1.6.1, released 2009/05/11
> /home/rkrug/grass/spearfish60/PERMANENT/cellhd/elevation.10m
> Segmentation fault
> rkrug at ecolmod:~$
Does gdalinfo still crash when you remove libgdal1-1.6.0-grass?  If it doesn't,
then that narrows it down to the gdal grass plugin.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
