[Qgis-developer] Qgis 1.2.0 - 1 Mac OS X Leopard - problem to
import psycopg
William Kyngesburye
woklist at kyngchaos.com
Sun Sep 13 14:45:07 EDT 2009
It's there, so maybe there's something I missed in the environment
setup. Which plugin are you trying to load?
I'm having other problems with Qgis and psycopg (separately) on Snow
Leopard, but I'll see if I can make sure it's working for the 1.3
release.
On Sep 13, 2009, at 11:20 AM, Luca Mandolesi wrote:
> Hi,
> I've installed Qgs 1.2.0 but when I try to a load a plugin which
> import psycopg2, python returns this message:
> from psycopg2 import *
> File "/Applications/Qgis.app/Contents/MacOS/../Resources/python/
> psycopg2/__init__.py", line 56, in
> from psycopg2 import tz
> ImportError: cannot import name tz
> I've try on my IDLE to import this module and all run correctly.
> Probably isn't embedded into psycopg2 that is present in Qgis?
> Thanks a lot
> luca
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
