[Qgis-developer] Create Multiple Polygons from Polygon and
Polylines
Luiz Motta
motta.luiz at gmail.com
Mon Sep 14 18:38:06 EDT 2009
Matt,
I see your picture and my idea are same operations:
1) Split:
Create polygons from layer polygon(source) with polylines(cut).
Polygon data -> Boundary Shapefile
Cut data -> Polylines segment (only two segments in picture showed) *
these lines cross or touch line boundary of polygon
Result -> three Polygons
2) Make polygon from polyline closed:
Polyline -> Polylines segment (only closed)
Result -> Polygon
3) Union:
Polygon -> polygon from result first item
Polygon -> polygon from result second item
Result -> All polygon
Strategy:
1) Separate type polylines: Closed (A) and not Closed(B)
2) Make polygon from A
3) Split polygon(big polygon) with B
4) Union result item 2 with result item 3.
Matthew Denno escreveu:
> Hi All,
> I am trying to programmaticly create a polygon shapefile from two
> separate input shapefiles. The first is a boundary polygon shapefile
> and the second is a a polyline shapefile that contains a number of
> segments (could many) that are spatially contained in the boundary
> polygon. The polyline segments either form closed areas or when
> connected end-to-end extend accross the polygon. I want to use the
> polylines to essentially cut the polygon into smaller polygons. Does
> anyone have any suggestions where to start with this problem. My
> question may not be completely clear so I have uploaded an example
> picture: http://www.flickr.com/photos/42311742@N02/3904105994/
> Thanks,
> Matt
> Qgis-developer mailing list
