[Qgis-developer] Create Multiple Polygons from Polygon and
Polylines
Matthew Denno
mgdenno at gmail.com
Tue Sep 15 22:09:39 EDT 2009
Thank you everyone for your help. I really appreciate it as I am trying to
learn the QGIS API and C++. I think that I have a solid plan to achieve my
goal now. However, I seem to be stuck on something that I think should be
simple, looping through the points of a QgsPolyline. If I iterate through
the Polylines and print out the point coordinates using ->at(int).x() I can
print out x1, y1, x2, and y2 with out problems. But, if I try to iterate
through the points of the polyline and print out the coordinates, I get x1,
y1 and then a bunch of junk values for the first 3 polylines and then
eventually it ends unexpectedly. Below is the code I am trying to use.
//now iterate through each polyline feature
while (mypPolylineLayer->nextFeature(currentPolylineFeat))
qDebug("feature = %i",f);
++f;
//get point geometry for current feature
QgsGeometry * currentPolylineGeom = currentPolylineFeat.geometry();
QgsPolyline * currentPolyline;
currentPolyline = ¤tPolylineGeom->asPolyline();
//this part works
qDebug() << "x1 = " << currentPolyline->at(0).x();
qDebug() << "y1 = " << currentPolyline->at(0).y();
qDebug() << "x2 = " << currentPolyline->at(1).x();
qDebug() << "y2 = " << currentPolyline->at(1).y();
QgsPolyline::const_iterator it = currentPolyline->constBegin();
for(; it != currentPolyline->constEnd(); ++it)
//this part doesn't
qDebug() << "x = " << (*it).x();
qDebug() << "y = " << (*it).y();
On Tue, Sep 15, 2009 at 5:48 AM, Carson Farmer <carson.farmer at gmail.com>wrote:
> Basically the polylines need to be "dissolved" first. Is there an existing
>> function to acheive this?
> You will likely need to do this yourself by finding segments that share a
> node, and creating a single line from all the associated QgsPoints.
>> Also, is there an enexisting function to union polygons programaticlly?
> Certainly, check out QgsGeometry.combine() in the docs.
> Carson
> Carson Farmer
> National Centre for Geocomputation
> John Hume Building,
> National University of Ireland, Maynooth,
> Maynooth,
> Co. Kildare,
> Ireland.
> www.carsonfarmer.com
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090915/8b2e7a1c/attachment.html
