[Qgis-developer] CRS database
Marco Hugentobler marco at hugis.net
Tue Sep 22 16:49:18 EDT 2009
Hi Martin
Usually this happens if there are several versions of the qgis libs around
(libqgis_core.so, etc...). Does it solve the problem if you remove the old
ones?
Regards,
Marco
Am Dienstag, 22. September 2009 22.42:57 schrieb Martin Landa:
> Hi,
> a few days ago I tried to compile QGIS, after enabling all available
> plugins I get error
> Could not open CRS database /resources/srs.db<br>Error(14): unable to
> open database file
> I tried 1.0, 1.1, 1.2, 1.3 and trunk, the same result. Do you have any
> idea where could be a problem?
> Thanks in advance, Martin
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Honrainweg 5
CH-8038 Zürich
marco at hugis.net
http://homepage.hispeed.ch/hugis/
