[Qgis-developer] CRS database
Tim Sutton
lists at linfiniti.com
Wed Sep 23 17:16:13 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Did you also try to uninstall everything and do a clean rebuild?
Sometimes it helps....
Regards
Tim
Martin Landa wrote:
> Hi,
> 2009/9/22 Marco Hugentobler <marco at hugis.net>:
>> Usually this happens if there are several versions of the qgis libs around
>> (libqgis_core.so, etc...). Does it solve the problem if you remove the old
>> ones?
> I am afraid it's not my case - I found only
> '/usr/local/lib/libqgis_core.so' in my system.
> Martin
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkq6kBYACgkQqk07qZdiYjdT0wCbBvOaRUF5aos7of8Cjr53aazH
lVgAni+f9KsSjL9LIvpJs0M6yYyxVMOh
=idZ5
-----END PGP SIGNATURE-----
