[Qgis-developer] Finding QGIS Version in Python Plugin?
Bruce, Bob (CON)
Bob.Bruce at gov.mb.ca
Wed Sep 23 17:54:20 EDT 2009
Hi Germán:
Thanks for that pointer. I changed the code to:
theVersionInt = QGis.QGIS_VERSION_INT
if theVersionInt / 100 > 102: # must conform to newer API standard call
QObject.connect(self.emitPoint, SIGNAL("canvasClicked(const QgsPoint &,\
Qt::MouseButton)"), self.setClipWindow)
else: # version is 1.2 or earlier - use older API standard call
QObject.connect(self.emitPoint, SIGNAL("canvasClicked(QgsPoint &,\
And now it works for all versions of QGIS.
Bob
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Germán Carrillo
Sent: Wednesday, September 23, 2009 2:58 PM
To: qgis-developer at lists.osgeo.org
Subject: Fwd: [Qgis-developer] Finding QGIS Version in Python Plugin?
Hi Bruce, you can use the QGis class from Core module:
http://doc.qgis.org/head/classQGis.html
Regards.
Germán
2009/9/23 Bruce, Bob (CON) <Bob.Bruce at gov.mb.ca>
Hi:
Is there a function to call to 'discover' the version of QGIS that you are running? I would like to be able to decide whether to call:
QObject.connect(self.emitPoint, SIGNAL("canvasClicked(QgsPoint &, Qt::MouseButton)"), self.setClipWindow)
or
QObject.connect(self.emitPoint, SIGNAL("canvasClicked(const QgsPoint &, Qt::MouseButton)"), self.setClipWindow)
based on the version of QGIS. This would allow me to have one version of my Image Clipper plugin.
Thanks,
Bob Bruce
** Bob Bruce, P.Eng. Geomatics Support Engineer
** bbruce at gov.mb.ca Manitoba Geomatics/Remote Sensing Branch,
** work # (204) 945-6636 1007 Century Street,
** FAX # (204) 945-1365 Winnipeg, Manitoba, Canada, R3H 0W4
** The Manitoba Centre for:
** Cadastral & Topographical Mapping, and Remote Sensing
** See us on the Web at: http://www.gov.mb.ca/conservation/geomatics/
** and: http://www.gov.mb.ca/conservation/geomatics/cada_mapping/index.html
** Check out our digital maps at: http://mlidata.gov.mb.ca/WPMLI
** and: https://mli2.gov.mb.ca/
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
|\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090923/24267d46/attachment-0001.html
