[Qgis-developer] [Fwd: Re: [Qgis-user] GdalTools
plugingeneratesan error on installation]
Tim Sutton
lists at linfiniti.com
Thu Sep 24 10:50:38 EDT 2009
Hi
Ok good - must be something ropey with their windows box.
Regards
Tim
------Original Message------
To: Tim Sutton
Cc: Paolo Cavallini
Cc: QGIS Developer
Subject: Re: [Qgis-developer] [Fwd: Re: [Qgis-user] GdalTools plugingeneratesan error on installation]
Sent: Sep 24, 2009 2:09 PM
Hi Tim,
On Thu, 24. Sep 2009 at 09:34:16 +0000, Tim Sutton wrote:
> Its probably the same issue of the stand alone installer (now fixed in build
> 1.3.0-3). Since we are linking to gdal 1.6 now, python must be set to look
> for gdal python pyd files in osgeo4w/apps/gdal1.6 instead of the default
> python libs path. No idea how to fix that in the osgeo4w dist, though no
> doubt Juergen will have an idea.
There's nothing to fix, because it works.
To have python bindings for GDAL 1.6 at all you need to install gdal16-python.
And the batch files used to start qgis call gdal16.bat, which setups PYTHONPATH
correctly. So if you start qgis using those batch files you should be all set.
Standalone applications need to use a similar approach.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Sent from my mobile phone.
