[Qgis-developer] Trunk not building
John C. Tull
john.tull at wildnevada.org
Wed Sep 30 20:16:48 EDT 2009
Before filing a bug, is anyone else experience a build failure with
the current trunk source?
Qt-4.5.2, sip-4.8.2, PyQt-4.5.4, OS X 10.6.1
Here's my error output:
[ 12%] Building CXX object src/core/CMakeFiles/qgis_core.dir/
qgssearchtreenode.o
In file included from /Developer/SDKs/MacOSX10.6.sdk/Library/
Frameworks/QtCore.framework/Headers/qchar.h:45,
from /Library/Frameworks/QtCore.framework/Headers/
qstring.h:45,
QString:1,
from /Users/jctull/sources/qgis/trunk/src/core/
qgslogger.h:23,
qgssearchtreenode.cpp:20:
/Developer/SDKs/MacOSX10.6.sdk/Library/Frameworks/QtCore.framework/
Headers/qglobal.h:311:6: warning: #warning "Support for this version
of Mac OS X is still preliminary"
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp: In
member function ‘QgsSearchTreeValue QgsSearchTreeNode::valueAgainst
(const QgsFieldMap&, const QgsAttributeMap&)’:
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:410:
error: ‘floor’ is not a member of ‘std’
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:414:
error: ‘pow’ is not a member of ‘std’
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:416:
error: ‘sqrt’ is not a member of ‘std’
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:418:
error: ‘sin’ is not a member of ‘std’
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:420:
error: ‘cos’ is not a member of ‘std’
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:422:
error: ‘tan’ is not a member of ‘std’
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:424:
error: ‘asin’ is not a member of ‘std’
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:426:
error: ‘acos’ is not a member of ‘std’
/Users/jctull/sources/qgis/trunk/src/core/qgssearchtreenode.cpp:428:
error: ‘atan’ is not a member of ‘std’
make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgssearchtreenode.o]
Error 1
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
make: *** [all] Error 2
