[Qgis-developer] erroR in py plugins
Paolo Cavallini
cavallini at faunalia.it
Thu Apr 1 14:17:05 EDT 2010
On Thu, 1 Apr 2010 16:34:18 +0100, Barry Rowlingson
<b.rowlingson at lancaster.ac.uk> wrote:
> Take qgis out of the equation and see if Rpy works with Python, with
> 'from rpy2 import *' from the python command line.
It works, both for py2.5.5 and 2.6 (I have both).
> If that works:
> then check that qgis is using the same python as your command line.
Qgis is using 2.6
> make it work :) It's not a qgis problem any more :)
So, stuck at the same place.
Thanks.
http://faunalia.it/pc
