AW: [Qgis-developer] IMPORTANT NOTICE to all python plugin authors
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Thu Apr 8 05:06:47 EDT 2010
Done for CadTools.
regards
Stefan
mit freundlichem Gruss
Stefan Ziegler
----- Originalnachricht -----
Von: "Borys Jurgiel" <borysiasty at aster.pl>
Gesendet: Mit, 7.4.2010 20:34
An: qgis-developer at lists.osgeo.org
Betreff: [Qgis-developer] IMPORTANT NOTICE to all python plugin authors
Dear Authors,
Due to removed qt3 support all plugin actions MUST send
a triggered() signal instead of the depreciated activated() one.
Please update your plugins by renaming the catched signal.
There is the list of affected plugins I can find below.
For more details, see http://trac.osgeo.org/qgis/ticket/1743
autosave/main.py: QObject.connect(self.action,SIGNAL("activated()"),self.showSettings)
cadtools/tools/arcintersectiontool.py: QObject.connect(self.act_intersect_arc, SIGNAL("activated()"), self.showDialog)
cadtools/tools/arcintersectiontool.py: QObject.connect(self.act_s2v, SIGNAL("activated()"), self.s2v)
cadtools/tools/lineintersectiontool.py: QObject.connect(self.act_s2s, SIGNAL("activated()"), self.s2s)
cadtools/tools/lineintersectiontool.py: QObject.connect(self.act_intersect_point, SIGNAL("activated()"), self.intersect_point)
cadtools/tools/lineintersectiontool.py: QObject.connect(self.act_intersect_line, SIGNAL("activated()"), self.intersect_line)
cadtools/tools/orthogonaldigitizertool.py: QObject.connect(self.act_ortho, SIGNAL("activated()"), self.orthodigitize)
cadtools/tools/rectangularpointstool.py: QObject.connect(self.act_rectpoints, SIGNAL("activated()"), self.showDialog)
cadtools/tools/rectangularpointstool.py: QObject.connect(self.act_selectlinesegment, SIGNAL("activated()"), self.selectlinesegment)
cadtools/tools/orthogonaltraversetool.py: QObject.connect(self.act_showDialog, SIGNAL("activated()"), self.showDialog)
cadtools/tools/orthogonaltraversetool.py: QObject.connect(self.act_select2vertex, SIGNAL("activated()"), self.select2vertex)
cadtools/tools/orthoelementsonsegmenttool.py: QObject.connect(self.act_ortholineandpoint, SIGNAL("activated()"), self.ortholineandpoint)
cadtools/tools/orthoelementsonsegmenttool.py: QObject.connect(self.act_selectvertexandline, SIGNAL("activated()"), self.selectvertexandline)
cartogram/Cartogram.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
cartogram/Cartogram.py: QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
cataloginpecreate/cataloginpe_qg.py: QtCore.QObject.connect(self.action, QtCore.SIGNAL("activated()"), self.run)
clickfu/clickFuUtils.py: QObject.connect(self,SIGNAL("activated()"),self.doit)
composer_plugin/composerplugin.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
contour/contour.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
dpsimplify/dpsimplify.py: QObject.connect( self.actionRun, SIGNAL( "activated()" ), self.run )
dpsimplify/dpsimplify.py: QObject.connect( self.actionAbout, SIGNAL( "activated()" ), self.about )
dumpfield/dumpfield.py: QObject.connect(self.action, SIGNAL("activated()"), self.dumpfield)
dumpfield/dumpfield.py: QObject.connect(self.action, SIGNAL("activated()"), self.loadtofield)
elevation/Elevation.py: QObject.connect(self.obtainAction, SIGNAL("activated()"), self.obtain)
elevation/Elevation.py: QObject.connect(self.aboutAction, SIGNAL("activated()"), self.about)
findbyattr/Findbyattr.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
GdalTools/tools/doClipper.py: self.connect(self.clipper, SIGNAL("deactivated()"), self.pauseClipping)
GdalTools/tools/doClipper.py: self.emit(SIGNAL("deactivated()"))
GeoCoding/GeoCoding.py: QObject.connect(self.action, SIGNAL("activated()"), self.geocode)
GeoCoding/GeoCoding.py: QObject.connect(self.configAction, SIGNAL("activated()"), self.config)
GeoCoding/GeoCoding.py: QObject.connect(self.reverseAction, SIGNAL("activated()"), self.reverse)
GeoCoding/GeoCoding.py: QObject.connect(self.aboutAction, SIGNAL("activated()"), self.about)
geofeeds/FeedPlugin.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
geoprocessing/geoprocessing.py: QObject.connect(self.actionGeoprocessing, SIGNAL("activated()"), self.run_geoprocessing_ctrl)
ghydraulic/ghydraulicplugin.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
HomeRange_plugin/HRplugin_main.py: QObject.connect(self.action, SIGNAL("activated()"), lambda method="all": self.showInterface(method))
HomeRange_plugin/HRplugin_main.py: QObject.connect(getattr(self, "action" + k), SIGNAL("activated()"), lambda method=k: self.showInterface(method))
image_clipper/imageclipper.py: QObject.connect(self.action, SIGNAL("activated()"), self.dlgImageClipper)
image_cutter/image_cutter.py: QObject.connect(self.action, SIGNAL("activated()"), self.dlgImageCutter)
image_cutter/image_cutter.py: QObject.connect(self.helpAction, SIGNAL("activated()"), self.helpWindow)
imagemap_plugin/imagemapplugin.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
imgboundary/imgboundary_qg.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
infotool/info.py: QObject.connect(self.action, SIGNAL("activated()"), self.inforun)
infotool/info.py: QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
infotool/info.py: QObject.connect(self.confaction, SIGNAL("activated()"), self.confrun)
joinlines/joinlines.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
manageR/pluginManager.py: SIGNAL("activated()"), self.callerlist[-1])
manageR/plugin.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
MapSheetAutoGeoRef/mapsheetgeoref.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
mergeshapes/mergeshapes.py: QObject.connect( self.actionRun, SIGNAL( "activated()" ), self.run )
mergeshapes/mergeshapes.py: QObject.connect( self.actionAbout, SIGNAL( "activated()" ), self.about )
metaedit/metaeditTool.py: QObject.connect(self.comboBoxFileLayer,SIGNAL("activated(int)"),self.layer_selected)
metaedit/metaedit.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
mirrormap/mirrormap.py: QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
mirrormap/mirrormap.py: QObject.connect(self.mirrormapaction, SIGNAL("activated()"), self.mirrormaprun)
mirrormap/mirrormap.py: QObject.connect(self.addrasteraction, SIGNAL("activated()"), self.addRasterLayer)
mirrormap/mirrormap.py: QObject.connect(self.addograction, SIGNAL("activated()"), self.addVectorLayer)
mirrormap/mirrormap.py: QObject.connect(self.adddbaction, SIGNAL("activated()"), self.helprun)
mirrormap/mirrormap.py: QObject.connect(self.addwmsaction, SIGNAL("activated()"), self.helprun)
multiqml/plugin.py: QObject.connect( self.actionRun, SIGNAL( "activated()" ), self.run )
multiqml/plugin.py: QObject.connect( self.actionAbout, SIGNAL( "activated()" ), self.about )
numericalVertexEdit/numericalvertexedit.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
OGR2Layers/ogr2Layers.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
openaddresses_converter/openaddressesconverter.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
osmpoly_export/polygenerator.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
photo2shape/photo2shape.py: QObject.connect( self.actionRun, SIGNAL( "activated()" ), self.run )
photo2shape/photo2shape.py: QObject.connect( self.actionAbout, SIGNAL( "activated()" ), self.about )
PostGisTools/PostGisTools.py: QObject.connect(self.toolfileAction, SIGNAL("activated()"),self.setToolsFile )
PostGisTools/PostGisTools.py: QObject.connect(self.aboutAction, SIGNAL("activated()"),self.about )
PostGisTools/PostGisTools.py: QObject.connect(self.actionlist[-1], SIGNAL("activated()"), self.callerlist[-1])
postgps/postgps.py: QObject.connect(self.action1, SIGNAL("activated()"), self.run)
qgisrest/qgisrest.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
qgisrest/qgisrest.py: QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
qgsAffine/qgsAffine.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
qgsAzimuth/qgsAzimuth.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
quantumnik/quantumnik.py: QObject.connect(self.action, SIGNAL("activated()"), self.toggle)
quantumnik/quantumnik.py: QObject.connect(self.action4, SIGNAL("activated()"), self.view_xml)
quantumnik/quantumnik.py: QObject.connect(self.action3, SIGNAL("activated()"), self.save_xml)
quantumnik/quantumnik.py: QObject.connect(self.action5, SIGNAL("activated()"), self.load_xml)
quantumnik/quantumnik.py: QObject.connect(self.action6, SIGNAL("activated()"), self.load_mml)
quantumnik/quantumnik.py: QObject.connect(self.action7, SIGNAL("activated()"),
quantumnik/quantumnik.py: QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
quicksaveqml/quicksaveqml.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
rastercalc/rasterlang.py: QObject.connect( self.action, SIGNAL( "activated()" ), self.run )
rastercalc/rastercalcdialog.py: QObject.connect( self.cmbPresets, SIGNAL( "activated( QString )" ), self.insertPreset )
rastercalc/rastercalc.py: QObject.connect( self.actionRun, SIGNAL( "activated()" ), self.run )
rastercalc/rastercalc.py: QObject.connect( self.actionAbout, SIGNAL( "activated()" ), self.about )
rasterCatalog/rastercatalogplugin.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
rasterinfo/rasterfileinfo.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
rasterinfo/rasterfileinfo.py: QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
rasterlang/main.py: QObject.connect(self.action,SIGNAL("activated()"),self.run)
rasterlang2/main.py: QObject.connect(self.action,SIGNAL("activated()"),self.run)
refmap/refmap.py: QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
refmap/refmap.py: QObject.connect(self.refmapaction, SIGNAL("activated()"), self.refmaprun)
rgb/Rgb.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
selectplus/selectionTools.py: QObject.connect(self, SIGNAL("activated()"), self.doit)
shapefile_splitter/shapefile_splitter.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
testplugin/plugin.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
testplugingl/plugin.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
threading_demo/threading_demo.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
threading_demo/threading_demo.py: QObject.connect(self.helpaction, SIGNAL("activated()"), self.helprun)
VectorFieldRenderer/VectorFieldRendererController.py: QObject.connect(action1,SIGNAL("activated()"), self.autoRescale )
VectorFieldRenderer/VectorFieldRendererController.py: QObject.connect(action2,SIGNAL("activated()"), self.enlarge )
VectorFieldRenderer/VectorFieldRendererController.py: QObject.connect(action3,SIGNAL("activated()"), self.shrink )
VectorFieldRenderer/VectorFieldRendererController.py: QObject.connect(action4,SIGNAL("activated()"), self.setScaleBoxOptions )
VectorFieldRenderer/VectorFieldRendererController.py: QObject.connect(action5,SIGNAL("activated()"), self.showHelp )
wps/qgswps.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
ziplayers/ziplayers_qg.py: QtCore.QObject.connect(self.action, QtCore.SIGNAL("activated()"), self.run)
zoom_to_point/zoomtopoint.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
zoom_to_point_BB/zoomtopoint.py: QObject.connect(self.action, SIGNAL("activated()"), self.run)
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
