[Qgis-developer] Compile error: class ???QgisApp??? does not have any field named ???mProxyFactory???
Ivan Mincik ivan.mincik at gmail.com
Wed Apr 14 15:36:25 EDT 2010
On Mon, Apr 12, 2010 at 10:36 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Ivan,
> On Mon, 12. Apr 2010 at 21:04:54 +0200, Ivan Mincik wrote:
>> cp: cannot stat `debian/tmp/usr/lib/qgis/libspatialiteprovider.so': No such
>> file or directory
> If you build for anything else but sid you need to add a debian/changelog entry
> with the appropiate distribution.  Otherwise the sid dependencies kick in -
> which is system spatialite - although that seems to be currently broken in sid
> too.
Thanks, yes I always make entry to debian/changelog with  appropriate
distribution.  As I said, latest trunk compiles well. Currently I am
using it.
