[Qgis-developer] manual wrong?
Paolo Cavallini cavallini at faunalia.it
Sat Apr 24 03:18:09 EDT 2010
Hi all.
What is te best way to correct this?
Paolo Cavallini ha scritto:
> I guess this is wrong in the manual (page 41, AKA 58):
> Your customized settings for QGIS are stored based on the operating system. , the
> settings are stored in your home directory in .qt/qgisrc.
More issues:
page 43 (59), a non sequitur:
When dealing with views, QGIS parses the view definition and
(phrase interrupted)
barchart diagramm >  barchart diagram
page 63 (69)
QGIS supports basic capabilities for editing vector geometries. Before reading any
further you should
note that at this stage editing support is still preliminary. Before performing any
edits, always make a
backup of the dataset you are about to edit.
this is no longer true, and shuld be modified.
repetition at page 21:
• Added ’newgis’ theme which is a revision by Anita Graser of the original GIS theme
by Robert
  Szczepanek
• Added ’newgis’ icon theme, a revision of the original ’gis’ theme
As you can see this is quite easy to set custom transparency, but it can be quite a
lot of work. Therefor
> Therefore
Alternativly> Alternatively
page 98 (114)Is this still true?
Remember this plugin works best with UMN MapServer WFS servers. It still could be,
that you might
experience random behavior and crashes. You can look forward to improvements in a
future version
of the plugin.
oage 99 (115)
not been many test against over WFS versions
remove "over"
accidentily>??
page 159 (175)
Examples of the different approaches are listed in Table
should read "8"
page 201 (217), top
Point creation,
comma should be removed
Also, citations are missing.
Paolo Cavallini: http://www.faunalia.it/pc
