[Qgis-developer] How to load a colour table on a raster,
programmatically (in python)?
Benoit de Cabissole
benoit at exigesa.com
Thu Aug 5 15:08:02 EDT 2010
Hi peter,
Me again, sorry!
I've implemented the code following your suggestions, but it throws the
following error:
File "C:\Documents and
Settings\Benoit/.qgis/python/plugins\bcccoltbl\cdlgTBL.py", line 373, in
accept
self.theLayer.rasterShader().setColorRampItemList(theTBL)
AttributeError: 'QgsRasterShader' object has no attribute
'setColorRampItemList'
Python version:
2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
QGIS version:
1.5.0-Tethys Tethys, 13923M
The code snippet is as follows:
367 # try to load the selected table directly on the selected raster
368 theTBL = self.ParseTBL(LTBL)
369 if not theTBL:
370 return
371 #
372 self.theLayer.setColorShadingAlgorithm( "ColorRampShader" )
373 self.theLayer.rasterShader().setColorRampItemList(theTBL)
374
self.theLayer.rasterShader().setColorRampType(QgsColorRampShader.ColorRamp_T
YPE.DISCRETE)
Problem is that I don't know the reason for the error!
Can it be that:
- theTBL is not valid? (see below how it is created)
- a typo?
- self.theLayer is truly a rasterLayer because the plugin will not load
otherwise.
- line 373 excecutes with no error
- A look at the C++ code for the raster properties 'Apply' colormap section
seems to indicate the code above is correct.
So I'm at a loss here. Do I miss an object?
Moreover, if I swap line 373 and 374 and run the code I do have the same
error:
accept
mp_TYPE.DISCRETE)
AttributeError: 'QgsRasterShader' object has no attribute 'setColorRampType'
Could you sort me out?
Code for reading the color ramp list:
def ParseTBL(self, LTBL):
Parse the colour table (QML file) to create a
QgsColorRampShader::ColorRampItem Struct
theTBLfile = os.path.join(self.FilePath,str(LTBL)) #
full name to the colour table to load
if not os.path.exists(theTBLfile):
QMessageBox.critical(self,MSG_BOX_TITLE,"ERROR: colour table not
found:\n"+str(theTBLfile))
return False
else:
sc = open(theTBLfile,'r')
ar = sc.readlines()
sc.close()
nC = 0
colorRampEntries = []
for a in ar:
if a.find(",") >= 0:
#value,r,g,b,alpha
#-0.65480690,1,1,1,255,
br = a.split(",")
red = int(br[1]) #red
gre = int(br[2]) #green
blu = int(br[3]) #blue
alp = int(br[4]) #alpha
colorRampEntries.append(QgsColorRampShader.ColorRampItem
colorRampEntries[nC].label = QString(" ")
colorRampEntries[nC].value = float(br[0])
colorRampEntries[nC].color = QColor(red, gre, blu, alp)
nC += 1
return colorRampEntries
The above code seems to work because on printing str(colorRampEntries) I've
got:
[<qgis.core.ColorRampItem object at 0x124D8810>, ...,
<qgis.core.ColorRampItem object at 0x12575108>]
Add printing str(theTBL[0].value)+" "+str(theTBL[0].color)
produces: 1.0 <PyQt4.QtGui.QColor object at 0x125785E0>
Sorry again for the length of this message, and take into consideration that
I'm very new to Python as well!
Thanks,
Benoit
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org]On Behalf Of Peter Ersts
> Sent: Thursday, 05 August 2010 15:33
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] How to load a colour table on a
> raster,programmatically (in python)?
> On 08/05/2010 05:25 AM, Benoit de Cabissole wrote:
> > Could you please point me to the function(s) that are used to
> match a custom
> > colour table (QgsColorRampShader?) to a raster?
> Howdy Benoit,
> First you will need to set the color shading algorithm for the raster,
> >> YourRasterLayer.setColorShadingAlgorithm( "ColorRampShader" )
> This creates a new shader for the raster.
> Next you will need to build your color ramp (palette). This is just a
> list of items of type QgsColorRampShader.ColorRampItem, Each item has
> three variables, lable (QString), color (QColor) , and value (double)
> Once you have your list you will need to give that list to the shader.
> >> YourRasterLayer.rasterShader().setColorRampItemList( YourColorRamp )
> Then you need to set the color ramp type:
> >> YourRasterLayer.rasterShader().setColorRampType( TheType )
> Where TheType is, INTERPOLATED, DISCRETE or EXACT. If your color ramp
> only had three entries:
> Label1, Red, 0
> Label2, Yellow, 127
> Label3, Green, 255
> exact - looks for an exact match at the time of shading, a value of 90
> would not be shaded.
> discrete - is a bin type approach, images pixels with values of 50, 70,
> or 90 would all be assigned the same color
> interpolated - is as the name says, 90 will be an interpolated color
> between Red and Yellow. In this case, more yellow than red as 90 is
> closer to 127 than 0.
> Hope that helps.
> -pete
> Peter J. Ersts, Software Developer
> American Museum of Natural History
> Center for Biodiversity and Conservation
> Central Park West at 79th Street
> New York, New York 10024
> Web: http://biodiversityinformatics.amnh.org
> Web: http://cbc.amnh.org
> Open Source,
> ...evolving through community cooperation to change the world bit by bit
> Quantum GIS Raster Development Team.
> Qgis-developer mailing list
