AW: Re: AW: [Qgis-developer] Qt Signal Error on Mac OS X
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Fri Aug 6 14:51:04 EDT 2010
Thanks for checking this! Wouldn't it be possible to disable this signal
for Mac OS X on the QGIS side? QGIS seems to run smoothly with this
error/bug. So I guess the method which is emitting the signal is never
used (?). But I'm just guessing...
regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: William Kyngesburye [mailto:woklist at kyngchaos.com]
> Gesendet am: Freitag, 6. August 2010 17:28
> An: Ziegler Stefan
> Cc: qgis-developer at lists.osgeo.org
> Betreff: Re: AW: [Qgis-developer] Qt Signal Error on Mac OS X
> I'm having the same error on Leopard. That sortof rules out
> a Python version issue (2.5 on Leopard, and 2.6 on Snow).
> Maybe it's something with the Mac build of Qt, nothing I can
> do about that. I can't think of anything else on the build side.
> I did notice that after the error, and cancelling the initial
> easyprint dialog, the composer window stays open, behind the
> main Qgis window. I didn't try anything in there to see if
> it was actually working.
> On Aug 6, 2010, at 12:38 AM, Ziegler Stefan wrote:
> > Hi William
> > I can't remember which version I downloaded. I used some
> dev builds few months ago and now downloaded 1.5, so both are
> possible. Have to check this.
> > You can find the plugin here:
> > http://www.catais.org/qgis/plugins.xml
> > It runs on trunk and on revision 13851 (on Linux).
> > regards
> > Stefan
> > On Aug 4, 2010, at 12:35 AM, Ziegler Stefan wrote:
> >> Hi
> >> I could need some help from the Mac OS X fraction. While
> trying to open a new composer window I get this error:
> >> Fehler bei der Ausführung von Python-Code:
> >> Traceback (most recent call last):
> >> File "/Users/stefan/.qgis/python/plugins/easyprint/easyprint.py",
> >> line 351, in createMap
> >> composition = composerView.composition()
> >> TypeError: type 'const QgsComposerItem*' is not supported
> as a native
> >> Qt signal type
> >> The suspicous code looks like this:
> >> beforeList = self.iface.activeComposers()
> >> self.iface.actionPrintComposer().trigger()
> >> afterList = self.iface.activeComposers()
> >> diffList = []
> >> for item in afterList:
> >> if not item in beforeList:
> >> diffList.append(item)
> >> composerView = diffList[0]
> >> composition.setPaperSize(float(paperwidth),
> float(paperheight))
> >> I'm using the 1.5 build from KyngChaos on Snow Leopard. It
> works on Linux. Thanks for any hints.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100806/a8f10139/attachment.html
