[Qgis-developer] Passing pointer arrays in python
Tim Sutton
lists at linfiniti.com
Sat Aug 7 14:34:37 EDT 2010
Hi
Many thanks Martin!
Regards
Tim
On 8/6/10, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Tim
> On Fri, Aug 6, 2010 at 11:09 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi Martin & other pythonistas
>> I'm trying to use
>> void QgsRasterLayer::computeMinimumMaximumFromLastExtent (
>> int
>> theBand, double * theMinMax )
>> Via python. However I can't seem to figure out how to pass the
>> arguments. I tried doing:
>> int
>> Looking at the generated sip file:
>> qgis/build/python/core/sipcoreQgsRasterLayer.cpp
>> If doesnt seem to internally use a double* for the a1 var. (line 2167
>> below). Is this a bug with the sip file defs, or am I missing how to
>> use the method?
> Indeed the wrapper has not been generated correctly because it has
> quite specific semantics (sip expected that only one value is going to
> be returned). As a workaround, I've added another override in r14017
> which can be handled automatically by sip:
>>>> layer.computeMinimumMaximumFromLastExtent(1)
> (0.0, 255.0)
> Cheers
> Martin
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
