[Qgis-developer] Developer cookbook in SVN
Otto Dassau otto.dassau at gmx.de
Mon Aug 9 04:21:23 EDT 2010
Am Sat, 7 Aug 2010 22:45:50 +0200
schrieb Martin Dobias <wonder.sk at gmail.com>:
> Hi Tim
> On Sat, Aug 7, 2010 at 10:24 PM, Tim Sutton <lists at linfiniti.com> wrote:
> > Hi Martin
> > This is a brilliant resource. We should be able to host it within the
> > qgis osgeo vm too if needed - do you need to do anything special to
> > build it other than apt-get install the sphinx binary.
> You're right, it could be put into qgis VM. It needs just the sphinx
> binary and a cron entry which would run 'make html' regularly.
> > Could we theme
> > it to look like our other documentation resources & web site - Werner
> > / Otto would you have time & inclination to look at that?
yes, I can have a look the next days.
 Otto
> Theming should be easy:
> http://sphinx.pocoo.org/theming.html
> > And how do we generate pdf's?
> Just tried it:
> make latex
> cd build/latex
> make all-pdf
> It results in a great looking PDF.
> Bye
> Martin
> Qgis-developer mailing list
