[Qgis-developer] Re: Incompatibilities between QGIS Spatialite
and Spatialite (CLI and GIS) created files
Noli Sicad
nsicad at gmail.com
Thu Aug 12 19:17:52 EDT 2010
Hi Giuseppe and Craig,
Thanks for your reply.
The QGIS 1.5 that I am using is installed using the standalone OSGeo4W
with Grass installer.
It is built using Spatialite 2.4.0 and code revision 13923M.
Regards,
Noli
On 8/12/10, Craig Leat <craig.leat at gmail.com> wrote:
> Hi Noli,
>> List of not opening spatialite database.
>> 1. The spatialite file found in this posting -subway_test.zip
>> http://forum.qgis.org/viewtopic.php?f=2&t=6103
>> It could not be opened properly in QGIS 1.5
> No rendering problems here - the polygons display just fine. However,
> the layer selection window reports "Unknown WKB" for the geometry
> type.
> $ cat /etc/issue
> Ubuntu 9.04
> $ ./qgis --help
> Quantum GIS - 1.5.0-Trunk 'Trunk' (12821)
> $ ogr2ogr --version
> GDAL 1.7.0, released 2010/01/19
> $ spatialite -version
> SpatiaLite version ..: 2.3.0 Supported Extensions:
> - 'VirtualShape' [direct Shapefile access]
> - 'VirtualText [direct CSV/TXT access]
> - 'VirtualNetwork [Dijkstra shortest path]
> - 'RTree' [Spatial Index - R*Tree]
> - 'MbrCache' [Spatial Index - MBR cache]
> - 'VirtualFDO' [FDO-OGR interoperability]
> - 'SpatiaLite' [Spatial SQL - OGC]
> PROJ.4 version ......: Rel. 4.6.1, 21 August 2008
> GEOS version ........: 3.0.0-CAPI-1.4.1
> 3.6.12
> Regards,
> Craig
