[Qgis-developer] PostGIS plugins menu
Giuseppe Sucameli
brush.tyler at gmail.com
Wed Aug 18 20:10:49 EDT 2010
Hi all,
On Wed, Aug 18, 2010 at 10:05 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Borys
> On Sun, Aug 15, 2010 at 11:59 AM, Borys Jurgiel <borysiasty at aster.pl>
> wrote:
> > My suggestion for now is to put everything to a PostGIS submenu within
> the
> > Plugins menu:
> > self.iface.addPluginToMenu('PostGIS', actionBlahBlah)
> Right. I will do that for postgis manager in the next release.
I moved all my 2 PostGis plugins (rt_sql-layer e rt_postgres-extractor)
to the PostGIS menu:
self.iface.addPluginToMenu('&PostGIS', self.action)
> Then we can modify the QgsInterface.addPluginToMenu method to put each
> > submenu either to the Plugins branch or to the main menu, so each user
> can
> > configure which plugin sumbenus are at hand. It's a five-minuts-fix to
> read
> > it from QSettings (still without any GUI for configuring it, but it's a
> step
> > forward).
> > The third step is the GUI. I started refactoring the Installer (just
> three
> > hours per month, so it's why no changes are commited) and with Martin and
> > Anne we plan to put it as a second tab of the manager. What about a third
> > tab "menus and toolbars", when an user can be able to:
> > 1. Select whether given submenu (e.g. PostGIS) goes to the main menu or
> the
> > Plugins menu
> > 2. Select whether given submenu creates its own toolbar or goes to the
> main
> > Plugin toolbar.
> > 3. Compose own toolbar(s) with a set of individual plugin buttons. It
> allows
> > to hide the native plugin toolbar and enable personalized ones, like
> > "Monday's tasks", "Tools useful for X-files processing etc"
> > 4. Save/load profiles (at least sets of plugins to be loaded - now I
> often
> > have to use --noplugins option to make qgis faster)
> > What do you think? The first two steps can be done in a moment.
> I like this idea of giving the users a chance to override the default
> placement. I would like to go even further - to allow user to
> manipulate individual actions created by the plugins - but that would
> probably need an addition to interface API (otherwise the
> identification of actions would depend on their name in current
> translation). I think of showing a tree widget to the user where nodes
> would be menus and submenus, the leafs would be individual actions.
> The user would be able to modify the tree in any way he likes: add new
> top level menus with some actions or just reorganize the 'Plugins'
> menu.
> If we end up updating the plugin interface, we could also proceed with
> defining the categories as we have discussed at the hackfests. Each
> plugin would be _strongly_ advised to suggest a category where it
> belongs, so ideally the users will not have to organize the plugins
> manually.
+1, would be great!
Cheers
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100819/827656b0/attachment.html
