[Qgis-developer] Integration of QGIS mapserver to svn?
Andreas Neumann
a.neumann at carto.net
Sat Aug 21 11:47:39 EDT 2010
Hi Andrea,
QGIS mapserver works as an Apache fcgi. So to enable QGIS-mapserver you
copy the executable to a directory configured for FCGI, enable fcgi in
Apache (easy to do in most Linux distributions) and start Apache. You
don't need to be logged in - also no GUI is needed. I am not sure if it
requires an XServer on the server at compile time, probably not. There
will be more information on installation soon.
Andreas
On 8/21/10 5:20 PM, Andrea Peri wrote:
> I don't know this plugin,
> but remenber a very old product from ESRI called.
> "ArcView for IMS" .
> That was an extension for arcview3 to be able to produce map for the web.
> The main problem was that the server must be logged in to produce a map,
> because the software need an environment and a GUI.
> Because this need of to be logged with an user to produce some maps
> that product was few usable and disappered early from market.
> I don't know if qgis is able to work without an environment and a GUI.
> Andrea Peri
> qwerty àèìòù
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100821/c8ff5f8d/attachment.html
