[Qgis-developer] Enchancing New Symbology - ColorRamp Edit
Benoit EXIGE benoit at exigesa.com
Sun Aug 22 03:09:18 EDT 2010
Hi Noli,
Did you have a look at the 1-band raster colour plugin?
I've posted it in the QGIS repository. It is flagged as experimental
so you will have to enable experimental plugin in the plugin manager.
I think it will respond to what you are looking for.
Cheers,
Benoit
On 22 Aug 2010, at 3:24, Noli Sicad <nsicad at gmail.com> wrote:
> Hi,
> It seems that QGIS has only 3 color ramps, probably we can improve it
> by adding more options and increase the class size as well.
> http://www.qgis.org/wiki/Symbology_RFC#Python_plugin
> Where is the "Color ramp dialogs"? Is this implemented?
> I find color ramps in R package quite flexible especially using ssplot
> for thematic mapping. Color Brewer is quite limited.
> ColorRamps
> http://bm2.genes.nig.ac.jp/RGM2/R_current/library/IDPmisc/man/IDPcolorRamp.html
> http://cran.r-project.org/web/packages/colorRamps/colorRamps.pdf
> Now, how can we hack QGIS 1.5 to add more color ramps pallete
> Arcgis is also using color ramps.
> ArcMap Edit color ramp
> http://www.tectonics.caltech.edu/gis/reference/color_ramp.html
> Noli
> Qgis-developer mailing list
