[Qgis-developer] qgis mapserver error
Luca Delucchi
lucadeluge at gmail.com
Thu Aug 26 07:59:08 EDT 2010
2010/8/25 Pirmin Kalberer <pi_ml at sourcepole.com>:
> Hi Luca,
> The error message says "Configuration file problem", which means, that no valid
> configuration (SLD or QGS file) was found.
> I guess that the world.qgis file in the test_qgis_mapserver directory is either
> missing or not readeable for the Apache process.
i have the file, this is my files inside test_qgis_mapserver
ls -lh /usr/lib/cgi-bin/test_qgis_mapserver/
total 20K
lrwxrwxrwx 1 root root 67 2010-08-24 09:45 qgis_mapserv.fcgi ->
/home/luca/compilati/qgis_svn/build/src/mapserver/qgis_mapserv.fcgi
-rwxr-xr-x 1 root root 1.5K 2010-08-24 10:06 wms_metadata.xml
-rwxr-xr-x 1 root root 9.3K 2010-08-25 17:50 world.qgs
> That the error XML message isn't valid is a bug...
ok
> Regards
> Pirmin
regards
Luca
