[Qgis-developer] Re: Openlayers plugin and Virtual Earth (i.e.Bing
Maps)
Noli Sicad
nsicad at gmail.com
Fri Dec 3 00:25:15 EST 2010
This is the screenshot (below) of offset - bing maps and trace
shapefile from google map.
https://352508258456434760-a-1802744773732722657-s-sites.googlegroups.com/site/qgisbingoffset/home/Screenshot.png?attachauth=ANoY7crKuHih7GmYN5reQr6Y2adfkYVgqdvhDvNfmzRyoIw0gph5YcpzEz5n8EtxTzrY_XSqDgfkmwUmV3Sb2qeW7Nq9XZ9VK7_aEglDxGUUSb4AHyLf0NjDPVdShf2JWF-VAF3W-kz-X5DQmLiqI8R-MidJwjxAFItZYuf4t3-kNiY2_nW4gdkaHkF2nvH8dcsmw3EIWKt1fO8SdSPQyoZKrwazx7oAdg%3D%3D&attredirects=0
Any ideas how can this offset be correct in Openlayers plugin?
It seems that JOSM manage to correct this offset.
http://lists.openstreetmap.org/pipermail/talk/2010-December/055151.html
Thanks.
Noli
On 12/3/10, Noli Sicad <nsicad at gmail.com> wrote:
> Hi,
> I am trying to add Virtual Earth (Bing Maps) to QGIS Openlayers plugin
> and I have trouble on the projection of Bing Maps (i.e. alignment). My
> shapefile layer (i.e.traces from the Google Maps) and other shapefile
> layers are off when I overlayed the Bing map (Bing Hybrid).
> Bing is far better Satellite imagery compare to Yahoo and Google. OSM
> is using Bing for traces lately as result of Steve Coast (OSM founder)
> working with Bing.
> http://wiki.openstreetmap.org/wiki/File:Selecting_Bing_in_JOSM.png
> I know that Bing uses different projection,
> http://www.cadmaps.com/gisblog/?p=80
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> Inserting this code above does not help at all.
> Here the entire code.
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <title>OpenLayers Google Hybrid Layer</title>
> <style type="text/css">
> body {
> margin: 0;
> #map {
> width: 100%;
> height: 100%;
> .olLayerGoogleCopyright {
> left: 2px;
> bottom: 2px;
> .olLayerGooglePoweredBy {
> left: 2px;
> bottom: 15px;
> .olControlAttribution {
> font-size: smaller;
> right: 3px;
> bottom: 4.5em;
> position: absolute;
> display: block;
> </style>
> <!-- this gmaps key generated for http://openlayers.org/dev/ -->
> <script
> src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
> <script src="OpenLayers.js"></script>
> <script type="text/javascript">
> var map;
> function init() {
> map = new OpenLayers.Map('map', {
> theme: null,
> controls: [],
> projection: new OpenLayers.Projection("EPSG:900913"),
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508.34,
> -20037508.34, 20037508.34, 20037508.34)
> var gmap = new OpenLayers.Layer.Google(
> "Google Hybrid",
> {type: G_HYBRID_MAP, numZoomLevels: 19,
> 'sphericalMercator': true}
> map.addLayer(gmap);
> map.setCenter(new OpenLayers.LonLat(0, 0), 2);
> </script>
> </head>
> <body onload="init()">
> <div id="map"></div>
> </body>
> </html>
> Any ideas how to solve this problem of non alignment of the layers using
> Bing.
> Thanks.
> Regards, Noli
