[Qgis-developer] bug in the pyqgis online plugin creator
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Fri Dec 3 07:06:50 EST 2010
Hi Gary
Well, what you describe is exactly what I did, and it gives me an
error when running 'make'.
Just now recreated a dummy plugin, just for confirming it.
So, to clarify:
1 - use the online plugin builder and create a new plugin
2 - unzip it and do some changes in the ui file (using QtDesigner)
3 - go to the terminal and type 'make'
4 - gaze at this output:
make: *** No rule to make target `compile', needed by `default'.  Stop.
5 - fixing it: open up the Makefile and delete the tabspace on line #7
6 - re-run 'make': BAM! now it works :)
Can you please reproduce this procedure and verify that it is not
working? Thank you
On Fri, Dec 3, 2010 at 3:57 AM, Gary Sherman <gsherman at geoapt.com> wrote:
> On 12/2/10 5:31 AM, Ricardo Filipe Soares Garcia da wrote:
>> Hi list
>> There is a bug in the generation of the Makefile in the online pyqgis
>> plugin builder [1].
>> I'm no expert on Makefile generation, but I think the only issue is an
>> evil tabspace, right after the 'compile' rule.
>> Didn't know where to report this, hopefully here is the right place.
>> [1] - http://pyqgis.org/builder/plugin_builder.py
> The Makefile is fine. When the plugin is generate it does a build so the
> targets in the Makefile have already been compiled. If you edit the .ui
> file or the resources.qrc and type make, it will rebuild as appropriate.
> -gary
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Chair, QGIS Project Steering Committee
> -Desktop GIS Book:
> *http://desktopgisbook.com
> -Geospatial Consulting & Hosting
> *http://geoapt.com
> "We work virtually everywhere"
> Qgis-developer mailing list
___________________________ ___ __
Ricardo Garcia Silva
