[Qgis-developer] Memory data provider persistence
Martin Dobias
wonder.sk at gmail.com
Mon Dec 6 04:57:41 EST 2010
On Mon, Dec 6, 2010 at 10:45 AM, Barry Rowlingson
<b.rowlingson at lancaster.ac.uk> wrote:
> On Mon, Dec 6, 2010 at 2:04 AM, Chris Crook <ccrook at linz.govt.nz> wrote:
>> So, for my requirement for memory provider persistance, the only real question is what is the right way to do it. Although Martin had suggested a spatialite database, my leaning is towards a simple QDataStream. A simple implementation could be (in crude pseudo code)
>> Qstring header("Qgis data file");
>> Int version = 1;
>> stream << header << version;
>> Foreach memory_provider
>> if provider < persist
>> stream << layer_id
>> stream << attribute_count
>> foreach attribute
>> stream << attribute_definition
>> stream << feature_count
>> foreach feature
>> stream << feature
>> This could readily be reloaded after the XML project file is read.
>> Because it is processed sequentially it would sit comfortably in a ZIP file and be sequentially read from it without needing to be extracted and then processed (as a spatialite database would need to be). It is portable between OS etc.
>> If the user actually wants a spatialite database, or any other format, then they can save the layer to that.
>> How does this sound to people?
> It sounds like you're just creating another spatial data format. Why
> not, on project exit, just go "You have unsaved memory data layers -
> would you like them converted to [gml|shapefile|spatialite|whatever]
> and reloaded before saving/qutting or do you want to lose them
> forever?".
I completely agree with Barry - to me it looks like a waste of time to
invent a new data format - exclusively readable just by QGIS - and
intended just to load/store some data from/to memory provider.
Additionally, memory provider was thought to represent just temporary
(nonpersistent) data - so asking the user to convert it to some other
format when exiting seems reasonable to me.
Regards
Martin
