[Qgis-developer] add postgis raster
Maurício de Paulo
mauricio.dev at gmail.com
Mon Dec 13 13:25:16 EST 2010
Seems like a gui bug on the plugin. I'm going to review it. But as it says,
it's failing to connect to the data. Are you using gdal 1.7 or higher?
Could you tell us the test evironment?
Thanks for the information.
Mauricio de Paulo
On Mon, Dec 13, 2010 at 4:09 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> Hi all.
> I'm getting repeated errors while loading PostGIS rasters in QGIS.
> Any idea?
> All the best.
> Errore durante l'esecuzione di codice Python:
> Traceback (most recent call last):
> File "/home/paolo/.qgis/python/plugins/wktraster/wktRaster.py", line 115,
> in listTables
> QMessageBox.warning(self.dlg,"Connection failed to "+conn)
> TypeError: arguments did not match any overloaded call:
> QMessageBox.warning(QWidget, QString, QString, QMessageBox.StandardButtons
> buttons=QMessageBox.Ok, QMessageBox.StandardButton
> defaultButton=QMessageBox.NoButton): not enough arguments
> QMessageBox.warning(QWidget, QString, QString, int, int, int button2=0):
> not enough
> arguments
> QMessageBox.warning(QWidget, QString, QString, QString, QString
> button1Text=QString(), QString button2Text=QString(), int
> defaultButtonNumber=0, int
> escapeButtonNumber=-1): not enough arguments
> Versione Python:
> 2.6.6 (r266:84292, Dec 12 2010, 15:29:35)
> [GCC 4.4.5]
> Versione di QGIS:
> 1.7.0-Trunk Trunk, 14778M
> Percorso Python: ['/home/paolo/.qgis/python/plugins/GeoCoding',
> '/home/paolo/.qgis/python/plugins/cswclient',
> '/home/paolo/.qgis/python/plugins/elevation',
> '/home/paolo/.qgis/python/plugins/GeoCoding', '/usr/share/qgis/python',
> '/home/paolo/.qgis/python', '/home/paolo/.qgis/python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib/python2.6',
> '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
> '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
> '/usr/local/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10',
> '/usr/lib/pymodules/python2.6', '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/home/paolo/.qgis/python/plugins/ziplayers/logic',
> '/home/paolo/.qgis/python/plugins/ziplayers/gui', '/usr/share/qgis/python',
> '/home/paolo/.qgis/python/plugins/cadtools/tools',
> '~/.qgis/python', '/home/paolo/.qgis/python/plugins/imgshowhide/logic',
> '/home/paolo/.qgis/python/plugins/imgshowhide/gui',
> '/usr/share/qgis/python/plugins/fTools/tools', '/usr/share/qgis/python/',
> '/usr/share/qgis/python/']
> Paolo Cavallini: http://www.faunalia.it/pc
> Qgis-developer mailing list
Mauricio de Paulo
Engenheiro Cartografo
MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101213/e88b15ed/attachment.html
