Re: best.Re: [Qgis-developer] Spatialite ’select’ statement as vector layer in QGIS
Ivan Mincik
ivan.mincik at gmail.com
Mon Dec 13 16:19:18 EST 2010
> What did you mean?
> The RT_Sql_Layer permits to load every PostGIS query, not table based only.
> So I cannot understand, what do you miss in RT_Sql_Layer?
Hi, I wrote example PLPGSQL function, which demonstrates the case
where I was not able to load query using RT SQL Layer. Now it works
perfectly.
So, hats off and thanks You a lot for Your work.
For reference, my test function is attached in this email.
Ivan
Type: text/x-sql
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101213/74643788/function.bin
