[Qgis-developer] Error for postgres's provider when
table(statement SELECT ) is outside public's schema
Noli Sicad
nsicad at gmail.com
Thu Dec 16 02:15:50 EST 2010
I input public in Schema and I got this error.
Unable to access the "public"."TableA" relation.
The error message from the database was:
ERROR: relation "public.TableA" does not exist
LINE 1: select * from "public"."TableA" limit 1
SQL: select * from "public"."TableA" limit 1
Noli
On 12/16/10, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Guiseppe,
> Thanks.
> In PostgIs, this query below works now.
> SELECT * FROM "public"."stands" AS "t_0" WHERE "t_0"."veg_type" = 'A'
> Now, my problem is I don't know what is the "Schema".
> What should I place in the Schema textbox? Where can I figure out the
> Schema?
> Noli
> On 12/16/10, Giuseppe Sucameli <sucameli at faunalia.it> wrote:
>> Hi Noli,
>> this one it's no a plugin error, it's a query syntax error.
>> On Thu, Dec 16, 2010 at 5:33 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>> Select * from Regions where NAME = "VENETO"
>> You still use double quotes wrapping values, instead you must use single
>> quotes.
>> Double quotes are for identifiers like table name, schema name and column
>> name.
>> Cheers.
>>> > Hi Ricardo,
>>> > In postgis error.
>>> > The plugin has the same problem when you checkbox is on for "save new
>>> > layer to database".
>>> > However, if I unchecked it this is the error.
>>> > Unable to execute the query.
>>> > ERROR: column "A" does not exist
>>> > LINE 1: ...ect * from (Select * from stands where veg_type = "A") as
>>> "s...
>>> > SQL: select * from (Select * from stands where veg_type = "A") as
>>> > "subQuery_0" limit 1
>>> > Noli
>>> >> Hi Ricardo,
>>> >> Spatialite database bug.
>>> >> The bug is in checkbox (on./check) "save new layer to database".
>>> >> When I unchecked (off), it works but the resulting map in TOC is "sql
>>> >> layer".
>>> >> The postgis bug, I don't know the reason since it does not work as
>>> >> well in the other postgis plugin (i.e PGManager).
>>> >> Noli
>>> >> On 12/16/10, Ricardo Filipe Soares Garcia da
>>> >> <ricardo.garcia.silva at gmail.com> wrote:
>>> >>> Hi Noli
>>> >>> I can't seem to reproduce any of your errors with my sample data.
>>> >>> Can you give me some more information? What queries are you trying?
>>> >>> Is it possible for you to send me some testing data?
>>> >>> On Thu, Dec 16, 2010 at 1:47 AM, Noli Sicad <nsicad at gmail.com>
>>> >>> wrote:
>>> >>>> Hi Ricardo,
>>> >>>> I got another error in 0.4, this time in PostGI. This is simple
>>> >>>> query.
>>> >>>> An error has occured while executing Python code:
>>> >>>> Traceback (most recent call last):
>>> >>>> File
>>> "/home/noli/.qgis/python/plugins/customdbquery/CustomDBQueryDialog.py",
>>> >>>> line 175, in parse_SQL_text
>>> >>>> self.execute_query(selectQuery)
>>> >>>> File
>>> >>>> line 187, in execute_query
>>> >>>> self.run_normal_query(createTableQuery, connection)
>>> >>>> File
>>> >>>> line 238, in run_normal_query
>>> >>>> cursor.execute(query)
>>> >>>> ProgrammingError: column "A" does not exist
>>> >>>> LINE 1: ...ne.Veg_TYPE_A AS (Select * from stands where veg_type =
>>> "A")
>>> >>>> Python version:
>>> >>>> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
>>> >>>> [GCC 4.4.3]
>>> >>>> QGIS version:
>>> >>>> 1.7.0-Trunk Trunk, 14914M
>>> >>>> The previous error was in Spatialite.
>>> >>>> Thanks.
>>> >>>> Noli
>>> >>> ___________________________ ___ __
>>> >>> Ricardo Garcia Silva
>>> >>> _______________________________________________
>>> >>> Qgis-developer mailing list
>>> >>> Qgis-developer at lists.osgeo.org
>>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Giuseppe Sucameli
