[Qgis-developer] Error for postgres's provider when
table(statement SELECT ) is outside public's schema
Giuseppe Sucameli
sucameli at faunalia.it
Thu Dec 16 02:25:06 EST 2010
On Thu, Dec 16, 2010 at 1:46 AM, Noli Sicad <nsicad at gmail.com> wrote:
> Is there simple way to delete the table in the database, not using SQL
> statement / query?
PG_manager -> delete table/view. Why not?
Cheers.
Thanks.
> Noli
> On 12/16/10, Ricardo Filipe Soares Garcia da
> <ricardo.garcia.silva at gmail.com> wrote:
> > Hi all
> > To celebrate the fixing of this bug by brushtyler (Guiseppe maybe?), I
> > have updated 'custom db query' to version 0.4.
> > The plugin's window is now modeless, and it stays on top of the QGIS
> > main window. So you can interact with the rest of QGIS while having
> > the plugin open. This way you can, for example remove your query
> > layers from the map.
> > On Tue, Dec 14, 2010 at 7:03 PM, Luiz Motta <motta.luiz at gmail.com>
> wrote:
> >> Hi Guiseppe,
> >> Sorry for the mistake on the author of the provider.
> >> I made both test, for both plugins, 'Custom database query' and 'Rt Sql
> >> Layer, and
> >> with the same result.
> >> When the table is inside public's schema don't have message of error,
> >> otherwise,
> >> i have the message of error, but the layer is created perfect.
> >> I saved the project of QGIS (with the created layer) and open again this
> >> project the message of error was showed.
> >> In this point isolat the factor of plugin, then, have some problem with
> >> provider.
> >> Regards,
> >> Luiz Motta
> >> 2010/12/14 Giuseppe Sucameli <sucameli at faunalia.it>
> >>> Hi Luiz and Ricardo,
> >>> On Tue, Dec 14, 2010 at 1:04 PM, Luiz Motta <motta.luiz at gmail.com>
> wrote:
> >>>> The author of provider told me about this problem, see ticket
> >>>> (https://trac.osgeo.org/qgis/ticket/3329).
> >>> to Luiz: as Ricardo wrote, he is the author of the plugin
> >>> (CustomDatabaseQuery),
> >>> not the author of the provider at all.
> >>> BTW, I'm the author of both the patches for executing a custom query
> with
> >>> postgres and spatialite provider, so I'm one of the guys you're
> searching
> >>> for :)
> >>> to Ricardo: the ticket told about an "Error for postgres's provider",
> not
> >>> custom
> >>> database query plugin issue.
> >>> Furthermore, the QGis trac is not for plugins' issues, except for those
> >>> that are
> >>> in trunk. For this reason we're working to create a plugins trac.
> >>> If you're sure the issue is only related to your plugin source code and
> >>> not to the
> >>> qgis functions called in your code, you should close the ticket as
> >>> invalid.
> >>>> SELECT
> >>>> l.id AS gid, l.the_geom AS the_geom
> >>>> FROM gis.tl_20101117_101056_limite l
> >>> Doesn't anyone confirm that it's a provider's issue, not just a plugin
> >>> issue??
> >>> Please, could you try to execute the same query using the RT Sql Layer
> >>> plugin,
> >>> in order to confirm the provider issue?
> >>> Thanks a lot.
> >>> Cheers.
> >>>> Please inform about your enviroment.
> >>>> It can be util for understand what is happened.
> >>>> Regards,
> >>>> Luiz Motta
> >>>>> Hi Luiz,
> >>>>> On Tue, Dec 14, 2010 at 2:43 AM, Luiz Motta <motta.luiz at gmail.com>
> >>>>> wrote:
> >>>>>> I am testing the 'Custom database query' plugins, where, i use
> layers
> >>>>>> outside public's schema.
> >>>>>> The plugin create the layer, but, before, i receive the message
> error
> >>>>>> about cursor od database.
> >>>>>> If the layers are inside public's schema not appear message.
> >>>>>> The one ticket is open, number 3329.
> >>>>> I'm unable to reproduce it, both 'Custom database query' and 'RT Sql
> >>>>> Layer' plugins
> >>>>> seems to work with tables not in the public schema.
> >>>>> Maybe does your layer contain invalid geometries?
> >>>>> Cheers.
> >>>>> Giuseppe Sucameli
> >>> Giuseppe Sucameli
> > ___________________________ ___ __
> > Ricardo Garcia Silva
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101216/361d7caa/attachment.html
