[Qgis-developer] OpenLayers plugin and Print Composer
Aaron Kreider
aaron at campusactivism.org
Thu Dec 16 17:09:31 EST 2010
I'm trying to print a layer of points (kml) on an Open Street Map. I'm
hoping to get the highest resolution possible - so I can print them out
at 600 dpi. I think I can do this by creating an image that is around
4800 by 6000 pixels.
QGIS 1.6
I use the OpenLayers plugin to get the OpenStreetMap layer.
I add the kml data. I zoom in a couple times (to the state of
Pennsylvania).
It looks fine in QGis. Now when I try to print it using "Print
Composer", I select "add a map" and create a box for the map. The map
shows up fine. But when I try to export it to an image (or pdf) it
shows my kml markers on a *completely different* open street map
background. It looks like it zoomed in 3-5 times on openstreet (and
changed the center point), but the kml layer keeps its original projection.
Is there any way I could get around this bug?
It looks like there is an OpenLayers bug. Is someone working on it?
Another person had the same problem:
http://forum.qgis.org/viewtopic.php?f=2&t=7674&p=16449#p16449
There is a ticket, but it looks like nobody is working on it:
http://trac.osgeo.org/qgis/ticket/3195
Aaron
Energy Justice Communities Map Developer - http://www.energyjustice.net/map
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101216/297a0641/attachment.html
