[Qgis-developer] Is it possible to re-use print composer code to
build a web service ?
Martin Dobias
wonder.sk at gmail.com
Mon Dec 20 10:46:01 EST 2010
On Mon, Dec 20, 2010 at 4:36 PM, Alessandro Pasotti <apasotti at gmail.com> wrote:
>> It seems that the segfault happens in the python finalization code.
>> Such crashes happen if the qt objects are deleted in wrong order.
>> Presumably the QApplication object has been deleted earlier than the
>> composition. That could be solved by various ways, for example,
>> delete the composition at the end or set QApplication to be parent of
>> the composition.
>> Since the code crashes in the finalization stage, you should get the
>> output png file anyway. Can you please check?
> Yes, the out.png is there but it contains a blank (white) image.
Looking at the code, I see that you create an instance of
QgsMapRenderer, but do not initialize. You should call its
setLayerSet() and setExtent() methods so that it knows what to render.
> adding
> c.setParent(app)
> did not help, nor did
> del c
> gdb bt is similar: still crashes in the destructor of QGraphicsScene.
I will try your code in the evening on my dev computer.
Martin
