[Qgis-developer] Re: Plugins starter plugin
Marco Bernasocchi
marco at bernawebdesign.ch
Mon Dec 20 16:44:02 EST 2010
Hi Borys,
I'm the developer of the Plugins starter Plugin, I just had a look at my
source, and there is no mismatch, init.py returns 0.3.2 and so I tagged
the plugin, the problem was that when I uploaded the zip file, the old
one (with the same name) was not overwritten. I just tested again and it
happened again. now I added an underscore to the zip file name and
everything is fixed, can somebody confirm this behaviour? is it maybe a bug?
ciao
Marco
Date: Sun, 19 Dec 2010 13:56:51 +0100
> From: Borys Jurgiel<borysiasty at aster.pl>
> Subject: Re: [Qgis-developer] Plugins starter plugin
> To: qgis-developer at lists.osgeo.org
> Message-ID:<201012191356.51150.borysiasty at aster.pl>
> Content-Type: Text/Plain; charset="utf-8"
> Ok, I'm not able to contact the author, so I've decreased the version number
> and now is ok.
> Dnia poniedziałek 13 grudnia 2010 o 19:48:50 Paolo Cavallini napisał(a):
>> Apparently it has the usual mismatch between file name and tags: it keeps
>> on asking to be upgraded.
>> A bit annoying.
>> All the best.
