[Qgis-developer] Loading CSV with geometry field
Chris Crook
ccrook at linz.govt.nz
Tue Dec 28 13:38:30 EST 2010
Hi Jude
If you are able to use QGis 1.7 this now can take a geometry column (formatted as well known text) in a CSV file using the delimited text plugin.
Cheers
Chris
________________________________________
Sent: 29 December 2010 00:33
To: qgis-developer at lists.osgeo.org
Subject: [Qgis-developer] Loading CSV with geometry field
I have a csv file with a geometry column. Quick question is how would this be loaded using the QGIS API, as a vector layer, given that the CSV delimited text layer only makes use of x and y co-ordinates?
Please help
Regards,
Jude Mwenda
Skype id: jmwenda
Twitter: www.twitter.com/judemwenda<http://www.twitter.com/judemwenda>
"Was ist mein Leben, wenn ich nicht mehr nützlich für andere."
Johann Wolfgang von Goethe
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
