[Qgis-developer] freehand plugin errors
Pavol Kapusta
pavol.kapusta at gmail.com
Wed Dec 29 13:52:33 EST 2010
Hi Giovanni,
I am really sorry, I did not answer to comment you left at reference
page to this plugin,but it was little bit busy time before Xmas.
1.) sorry, but you should read that page carefully (and please look at
the pictures, too). You should not use other tolerance value except
zero, while are you digitizing layers, which are projected inlat/lon CRSs.
2.) This is really bug and i will try to do something with this.
Regards
Pavol
Dňa 29.12.2010 18:35, Giovanni Manghi wrote / napísal(a):
> Hi all,
> (trying to reach the Freehand Editing plugin developer)
> I'm getting the following errors under both linux (ubuntu) and windows:
> *) if the spinner is configured to something other than "0" then the
> plugin always throws "The geometry of the feature you just added isn't
> valid. Do you want to use it anyway?", but then even clicking "yes"
> returns no line/polygon.
> *) single clicking with the "freehand editing" tool always returns a
> python error:
> Traceback (most recent call last):
> File
> "/home/gio/.qgis/python/plugins/freehandEditing/freehandediting.py",
> line 152, in createFeature
> s = g.simplify(tolerance)
> AttributeError: 'NoneType' object has no attribute 'simplify'
> Cheers!
> -- Giovanni --
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101229/4a1985e3/attachment.html
