[Qgis-developer] Re: QGIS.pro, Qt Creator and Android - Qt
Creator Integration
Mayeul Kauffmann
mayeul.kauffmann at free.fr
Thu Dec 30 09:32:23 EST 2010
I have not seen a way to save the project options explicitly, but I have
tested that at least some of the compiling options are saved
automatically in a CMakeLists.txt.user file which is automatically
created next to CMakeLists.txt.
For a discussion on a similar issue:
http://stackoverflow.com/questions/3898763/where-does-qtcreator-with-cmake-store-run-and-build-settings-and-how-to-set-via
Still maybe part of the following has to be done every time.
Here are some steps I've used:
If I'm correct, with qtcreator, you have to put the correct cmake
parameters *the first time* you configure the project (hence, when you
open the CMakeLists.txt and click "Run CMake")
Here are the options I use myself
-DCMAKE_INSTALL_PREFIX=~/bin/myqgisdirectory -DCMAKE_BUILD_TYPE=Debug
-DENABLE_TESTS=False -DWITH_MAPSERVER=False
The following one is mandatory if you want to control where to install
the compiled files (choose a place where you do not need sudo rights to
write):
You can also configure the various build steps.
You'll find all of this detailed here:
http://blog.urbylog.info/2010/05/plasma-applet-development-walk-through_12.html
Mayeul
Le jeudi 30 décembre 2010 à 08:45 +0200, Tim Sutton a écrit :
> Hi Noli
> I'm not an expert in Qt-Creator (I'm a vim guy!) but the last time I
> tested it, I didnt see any option to create a .pro file from the
> CMakeLists.txt based project. In fact that was one of my irritations
> of trying to use creator - having to re-read in the project from the
> CMakeLists.txt file every time. But it could be just that I missed
> something essential in the process.
> I'm also interested in making an android port at some point...
> Regards
> Tim
> On Thu, Dec 30, 2010 at 6:18 AM, Noli Sicad <nsicad at gmail.com> wrote:
> > Hi,
> > OK. I managed to install cmake package.
> > But still I don't what should be in the Qgis.pro after I created this project?
> > Anybody can post what should be in entries in Qgis.pro?
> > Noli
> > On 12/30/10, Noli Sicad <nsicad at gmail.com> wrote:
> >> Hi,
> >> I am trying to create a Qgis.pro (i.e. QGIS Qt Creator Project) based
> >> on this instruction [1].
> >> I am stuck on this step 3.
> >> 3. Run cmake in CMake Wizard. You can run it after adding project for
> >> this you should navigate to cmake build directory it is qtcreator-build
> >> in
> >> project root and run ccmake .. like usually);
> >> There are a lot of cmake files in the cmake directory, which one should I
> >> use?
> >> Anyway, anybody has exciting Qgis.pro (Qt Creator project) already and
> >> like to share it.
> >> I like to try to compile Qgis in Qt - Android lighthouse and see what
> >> happen.
> >> You watch the video on Android - Qt Creator Integration here - Video.
> >> http://code.google.com/p/android-lighthouse/wiki/QtCreatorIntegration
> >> Anybody interested in QGIS mobile for Android?
> >> Thanks. Noli
> >> [1] http://www.osgeo.org/pipermail/qgis-developer/2009-October/007832.html
> >> Using QtCreator with QGis is easy. To open QGis in it you should do:
> >> 1. In menu File->Open File or Project (Ctrl+O);
> >> 2. In open file dialog find CMakeLists.txt in the root of QGIs
> >> (/usr/local/src/qgis_trunk/CMakeLists.txt) and open it;
> >> in
> >> 4. After that QtCreator adds the new project with name qgis-1.x.x.
> >> 5. If you need to correct cmake options you can do it now (see 3);
> >> 6. Compile QGis (Ctrl+B);
> >> 7. Switch to tab Projects. In section Build Settings->Build Steps push
> >> Details button and add in Additional arguments: install.
> >> 8. In section Run Settings push +Add and select in combo box Custom
> >> Executable then push Details and add in Executable:
> >> /patch/to/qgis/executable (/usr/local/bin/qgis);
> >> 9. Start Debugging QGis: F5.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
