[Qgis-developer] sip compile error
Germán Carrillo carrillo.german at gmail.com
Thu Feb 4 11:09:52 EST 2010
Thank you Martin.
Finally, I was unable to revert changes (some compilations) done on my
Ubuntu, so I had to install the last version (9.10).
Is good to see QGIS again!
Regards.
Germán
El 29 de enero de 2010 14:39, Martin Dobias <wonder.sk at gmail.com> escribió:
> 2010/1/26 Germán Carrillo <carrillo.german at gmail.com>:
> > Hi Martin,
> > Currently the imports from PyQt4 and qgis.core are returning the
> > Segmentation fault. :(
> Compilation with sip 4.7 should be working again in trunk, so you
> might want to try it again with stock distribution packages.
> Martin
  |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100204/7b942a5d/attachment.html
