[Qgis-developer] QGIS Canvas API : Hello Word
Michael musset
mickamusset at gmail.com
Sat Feb 6 22:46:19 EST 2010
if it can help :
Updating goal targets....
Considering target file
`python/plugins/plugin_installer/CMakeFiles/pluginstaller.dir/build'.
File `python/plugins/plugin_installer/CMakeFiles/pluginstaller.dir/build'
does not exist.
Considering target file `pluginstaller'.
File `pluginstaller' does not exist.
`python/plugins/plugin_installer/CMakeFiles/pluginstaller'.
File `python/plugins/plugin_installer/CMakeFiles/pluginstaller' does
not exist.
Looking for an implicit rule for
Trying pattern rule with stem `pluginstaller'.
Trying implicit prerequisite
`python/plugins/plugin_installer/CMakeFiles/pluginstaller,v'.
`python/plugins/plugin_installer/CMakeFiles/RCS/pluginstaller,v'.
`python/plugins/plugin_installer/CMakeFiles/RCS/pluginstaller'.
`python/plugins/plugin_installer/CMakeFiles/s.pluginstaller'.
`python/plugins/plugin_installer/CMakeFiles/SCCS/s.pluginstaller'.
No implicit rule found for
`python/plugins/plugin_installer/ui_qgsplugininstallerbase.py'.
File `python/plugins/plugin_installer/ui_qgsplugininstallerbase.py'
does not exist.
`../python/plugins/plugin_installer/qgsplugininstallerbase.ui'.
Trying pattern rule with stem `qgsplugininstallerbase.ui'.
`../python/plugins/plugin_installer/qgsplugininstallerbase.ui,v'.
`../python/plugins/plugin_installer/RCS/qgsplugininstallerbase.ui,v'.
`../python/plugins/plugin_installer/RCS/qgsplugininstallerbase.ui'.
`../python/plugins/plugin_installer/s.qgsplugininstallerbase.ui'.
`../python/plugins/plugin_installer/SCCS/s.qgsplugininstallerbase.ui'.
Finished prerequisites of target file
No need to remake target
Must remake target
[ 93%] Putting child 0x09174c60
(python/plugins/plugin_installer/ui_qgsplugininstallerbase.py) PID 23899 on
the chain.
Live child 0x09174c60
Reaping winning child 0x09174c60 PID 23899
Generating ui_qgsplugininstallerbase.py
Live child 0x09bdc990
(python/plugins/plugin_installer/CMakeFiles/pluginstaller.dir/all) PID 23898
(python/plugins/plugin_installer/ui_qgsplugininstallerbase.py) PID 23900
Reaping winning child 0x09174c60 PID 23900
(python/plugins/plugin_installer/ui_qgsplugininstallerbase.py) PID 23902
File "/usr/bin/pyuic4", line 3, in ?
import PyQt4.uic.pyuic
ImportError: No module named PyQt4.uic.pyuic
Reaping losing child 0x09174c60 PID 23902
make[2]: *** [python/plugins/plugin_installer/ui_qgsplugininstallerbase.py]
Error 1
Removing child 0x09174c60 PID 23902 from chain.
Reaping losing child 0x09bdc990 PID 23898
make[1]: ***
[python/plugins/plugin_installer/CMakeFiles/pluginstaller.dir/all] Error 2
Removing child 0x09bdc990 PID 23898 from chain.
Reaping losing child 0x0a01f3d0 PID 21183
make: *** [all] Error 2
Removing child 0x0a01f3d0 PID 21183 from chain.
On Sat, Feb 6, 2010 at 8:45 PM, Michael musset <mickamusset at gmail.com>wrote:
> and my ccmake looks like that :
> BINDINGS_GLOBAL_INSTALL
> OFF
> BISON_EXECUTABLE
> /usr/bin/bison
> EXPAT_INCLUDE_DIR
> /usr/include
> EXPAT_LIBRARY
> /usr/lib/libexpat.so
> FLEX_EXECUTABLE
> /usr/bin/flex
> GDAL_CONFIG
> /usr/bin/gdal-config
> GDAL_CONFIG_PREFER_FWTOOLS_PAT
> /bin_safe
> GDAL_CONFIG_PREFER_PATH
> /bin
> GDAL_INCLUDE_DIR
> /usr/include/gdal
> GDAL_LIBRARY /usr/lib/libgdal1.5.0.so
> GEOS_CONFIG
> /usr/bin/geos-config
> GEOS_CONFIG_PREFER_PATH
> /bin
> GEOS_INCLUDE_DIR
> /usr/include
> GEOS_LIBRARY
> /usr/lib/libgeos_c.so
> GEOS_LIB_NAME_WITH_PREFIX
> -lgeos_c
> GRASS_PREFIX
> GSL_CONFIG
> /usr/bin/gsl-config
> GSL_CONFIG_PREFER_PATH
> /bin
> GSL_EXE_LINKER_FLAGS
> -Wl,-rpath,
> PEDANTIC
> OFF
> POSTGRESQL_PREFIX
> POSTGRES_CONFIG
> /usr/bin/pg_config
> POSTGRES_CONFIG_PREFER_PATH
> /bin
> POSTGRES_INCLUDE_DIR
> /usr/include/postgresql
> POSTGRES_LIBRARY
> /usr/lib/libpq.so
> PROJ_INCLUDE_DIR
> /usr/include
> PROJ_LIBRARY
> /usr/lib/libproj.so
> PYRCC4_PROGRAM
> /usr/bin/pyrcc4
> PYTHON_LIBRARY /usr/lib/libpython2.6.so
> PYUIC4_PROGRAM
> /usr/bin/pyuic4
> QT_QMAKE_EXECUTABLE
> /usr/bin/qmake
> QWT_INCLUDE_DIR
> QWT_INCLUDE_DIR-NOTFOUND
> QWT_LIBRARY
> QWT_LIBRARY-NOTFOUND
> SVNVERSION /usr/bin/svnversion
> On Sat, Feb 6, 2010 at 8:11 PM, Michael musset <mickamusset at gmail.com>wrote:
>> hey again,
>> well now i'm trying to compile myself qgis with following this tutorial :
>> http://linfiniti.com/2009/11/compiling-qgis-under-ubuntu-9-10/
>> when i'm trying to compile qgis 'm getting this error :
>> but i've already these package : python-qt4 python-qt4-dev
>> pyqt4-dev-tools
>> here is other information :
>> installer/ui_qgsplugininstallerbase.py] Error 1
>> make[1]: ***
>> micka at micka-laptop:~/dev/cpp/qgis/build$ whereis python
>> python: /usr/bin/python2.6 /usr/bin/python2.5 /usr/bin/python
>> /usr/bin/python2.6-dbg-config /usr/bin/python2.4 /usr/bin/python2.4-config
>> /usr/bin/python2.6-dbg /usr/bin/python2.6-config /etc/python2.6
>> /etc/python2.5 /etc/python /etc/python2.4 /usr/lib/python2.6
>> /usr/lib/python3.0 /usr/lib/python2.5 /usr/lib/python2.4
>> /usr/local/bin/python /usr/local/bin/python2.4 /usr/local/lib/python2.6
>> /usr/local/lib/python2.5 /usr/local/lib/python2.4 /usr/include/python2.6
>> /usr/include/python2.5 /usr/include/python2.5_d /usr/include/python2.4
>> /usr/include/python2.6_d /usr/share/python /usr/share/man/man1/python.1.gz
>> micka at micka-laptop:~/dev/cpp/qgis/build$ which python
>> what is wrong ? thx for your help ^^ ( ubuntu 9.10 )
>> On Sat, Feb 6, 2010 at 7:03 PM, Anne Ghisla <a.ghisla at gmail.com> wrote:
>>> On Sat, Feb 6, 2010 at 7:57 PM, Michael musset <mickamusset at gmail.com>
>>> wrote:
>>> > Hi,
>>> > i'm trying to follow this tutorial :
>>> > http://blog.qgis.org/node/10
>>> > and when i tape the command cmake .. i'm getting this error :
>>> > CMake Error: The source directory "/home/micka" does not appear to
>>> contain
>>> > CMakeLists.txt.
>>> > Specify --help for usage, or press the help button on the CMake GUI.
>>> Hi Michael,
>>> the code snippet misses
>>> cd build/
>>> before running cmake. cmake .. means that CMakeLists.txt will be
>>> searched in the parent directory (correct me if wrong).
>>> hope this helps and happy hacking :)
>>> Anne
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100207/99216e50/attachment-0001.html
