[Qgis-developer] New symbology rendering loop question
Chris Crook
ccrook at linz.govt.nz
Sun Feb 14 18:25:30 EST 2010
Hi
I'm using the V2 symbology and finding that it doesn't allow me to break out of the rendering loop once it has started. When I open a large layer (several million polygons), and they are all within the current extents, this means it can take a long time to render, and I cannot do anything about it till it finishes :-(
I see in the old symbology rendering loop (qgsvectorlayer.cpp, about 976) there is the following code
if ( rendererContext.renderingStopped() )
break;
#ifndef Q_WS_MAC //MH: disable this on Mac for now to avoid problems with resizing
if ( mUpdateThreshold > 0 && 0 == featureCount % mUpdateThreshold )
emit screenUpdateRequested();
emit drawingProgress( featureCount, totalFeatures );
qApp->processEvents();
else if ( featureCount % 1000 == 0 )
#else
Q_UNUSED( totalFeatures );
#endif //Q_WS_MAC
But looking in the new symbology rendering loop (about line 721), there is no equivalent code.
I'm just wondering if there is any reason why this was left out? (And as an obvious corollary, could it be put in!)
Cheers
Chris
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100215/3c1a50ab/attachment.html
