[Qgis-developer] Fwd: Qgis, windows, python & sqlalchemy
    Luca Mandolesi
    mandoluca at gmail.com
    Tue Feb 16 13:50:05 EST 2010
Hi to alls,
I've somes problems to make running my pyarchinit plugin under windows.
Pyarchinit use sqlalchemy and under mac os x and Linux, all run properly.
It's possible make using the python installed under windows and not the
embedded into Qgis, or put sqlalchemy as psycopg2 into the distribution?
Let me know! 8 )
Bye bye and thank you!
Luca
Under windows I receive this error:
  File "C:/Documents and Settings/Administrator/.qgis//python/plugins
\pyarchinit\pyarchinit_Site_mainapp.py", line 217, in
on_pushButton_save_pressed
    test_insert = self.insert_new_rec()
\pyarchinit\pyarchinit_Site_mainapp.py", line 234, in insert_new_rec
    self.DB_MANAGER.max_num_id(self.TABLE_NAME, self.ID_TABLE)+1,
\pyarchinit\modules\db\pyarchinit_db_manager.py", line 262, in
max_num_id
    table = Table(self.id_table, self.metadata, autoload = True)
  File "c:\python25\Lib\site-packages\sqlalchemy\schema.py", line 108,
in __call__
    return type.__call__(self, name, metadata, *args, **kwargs)
  File "c:\python25\Lib\site-packages\sqlalchemy\schema.py", line 236,
in __init__
    _bind_or_error(metadata).reflecttable(self,
include_columns=include_columns)
  File "c:\python25\Lib\site-packages\sqlalchemy\engine\base.py", line
1265, in reflecttable
    self.dialect.reflecttable(conn, table, include_columns)
  File "c:\python25\Lib\site-packages\sqlalchemy\databases
\postgres.py", line 638, in reflecttable
    c = connection.execute(t, table=table_oid)
824, in execute
    return Connection.executors[c](self, object, multiparams, params)
874, in _execute_clauseelement
    return self.__execute_context(context)
896, in __execute_context
    self._cursor_execute(context.cursor, context.statement,
context.parameters[0], context=context)
946, in _cursor_execute
    self.engine.logger.info(repr(parameters))
  File "C:\OSGeo4W\apps\Python25\lib\logging\__init__.py", line 985,
in info
    apply(self._log, (INFO, msg, args), kwargs)
  File "C:\OSGeo4W\apps\Python25\lib\logging\__init__.py", line 1101,
in _log
    self.handle(record)
  File "C:\OSGeo4W\apps\Python25\lib\logging\__init__.py", line 1111,
in handle
    self.callHandlers(record)
  File "C:\OSGeo4W\apps\Python25\lib\logging\__init__.py", line 1148,
in callHandlers
    hdlr.handle(record)
  File "C:\OSGeo4W\apps\Python25\lib\logging\__init__.py", line 655,
in handle
    self.emit(record)
  File "C:\OSGeo4W\apps\Python25\lib\logging\__init__.py", line 757,
in emit
    self.handleError(record)
  File "C:\OSGeo4W\apps\Python25\lib\logging\__init__.py", line 706,
in handleError
    traceback.print_exception(ei[0], ei[1], ei[2], None, sys.stderr)
  File "C:\OSGeo4W\apps\Python25\lib\traceback.py", line 128, in
print_exception
    print_tb(tb, limit, file)
  File "C:\OSGeo4W\apps\Python25\lib\traceback.py", line 70, in
print_tb
    '  File "%s", line %d, in %s' % (filename,lineno,name))
  File "C:\OSGeo4W\apps\Python25\lib\traceback.py", line 16, in _print
    file.write(str+terminator)
IOError: [Errno 9] Bad file descriptor
Versione Python:
2.5.4 (r254:67916, Dec 23 2008, 15:10:54) [MSC v.1310 32 bit (Intel)]
Percorso Python: ['C:/Documents and Settings/Administrator/.qgis//
python/plugins\\pyarchinit\\modules\\gui', 'C:/Documents and Settings/
Administrator/.qgis//python/plugins\\pyarchinit\\modules\\gis', 'C:/
Documents and Settings/Administrator/.qgis//python/plugins\\pyarchinit\
\modules\\db', 'C:/Documents and Settings/Administrator/.qgis//python/
plugins\\pyarchinit\\modules\\utility', 'C:/Documents and Settings/
Administrator/.qgis//python/plugins\\pyarchinit', 'C:/OSGeo4W/apps/
qgis-unstable/./python', 'C:/Documents and Settings/
Administrator/.qgis//python', 'C:/Documents and Settings/
Administrator/.qgis//python/plugins', 'C:/OSGeo4W/apps/qgis-unstable/./
python/plugins', 'C:\\OSGeo4W\\apps\\gdal-16\\pymod', 'C:\\', 'C:\
\WINDOWS\\system32\\python25.zip', 'C:\\OSGeo4W\\apps\\Python25\
\DLLs', 'C:\\OSGeo4W\\apps\\Python25\\lib', 'C:\\OSGeo4W\\apps\
\Python25\\lib\\plat-win', 'C:\\OSGeo4W\\apps\\Python25\\lib\\lib-tk',
'C:\\OSGeo4W\\apps\\qgis-unstable\\bin', 'C:\\OSGeo4W\\apps\
\Python25', 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages', 'C:\
\OSGeo4W\\apps\\Python25\\lib\\site-packages\\win32', 'C:\\OSGeo4W\
\apps\\Python25\\lib\\site-packages\\win32\\lib', 'C:\\OSGeo4W\\apps\
\Python25\\lib\\site-packages\\Pythonwin', 'C:\\OSGeo4W\\apps\
\Python25\\lib\\site-packages\\wx-2.8-msw-unico
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100216/99d1636d/attachment.html
