[Qgis-developer] Proposal: Add Qwt as a soft dependency for GPS
integration
Tim Sutton
lists at linfiniti.com
Wed Jan 6 05:00:35 EST 2010
Hi All
Marco and I have been working on C++ based GPS integration into QGIS
core. The work has been sponsored by Navigo (http://www.gonavigo.ca/).
There are two parts:
- a gps background process that communicates with a GPS and extracts
nmea strings and then propogates them to any listing classes
- a user interface, implemented as a dock panel that shows position,
signal strength bar chart, satellite polar chart, options
Similarly to Martin's gps project, the gps ui can be used to capture
features (and attributes using the normal attribute dialog mechanism).
The ui part uses Qwt for the charting functions. I would like to
propose that we add Qwt5 as a soft dependency. If it is not present,
the GPS ui parts will not be built (the background process part will
still be built. Could you please let us know if you are happy for the
inclusion of this soft dependency - and the GPS code itself?
If on, the other hand, people are inclined to make Qwt a hard
dependency, that would be good to because I can then replace the
raster props dialog histogram with a better charting implementation.
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
