[Qgis-developer] Re: Compile failure in trunk - symbology-ng
python bindings
William Kyngesburye
woklist at kyngchaos.com
Sat Jan 16 14:33:45 EST 2010
On Jan 16, 2010, at 1:09 PM, Gary Sherman wrote:
> On Sat, Jan 16, 2010 at 8:30 AM, John C. Tull <john.tull at wildnevada.org> wrote:
>> Hi All,
>> On Jan 16, 2010, at 3:45 AM, Martin Dobias wrote:
>>> On Sat, Jan 16, 2010 at 7:00 AM, Gary Sherman <gsherman at mrcc.com> wrote:
>>>> This problem is solved by upgrading sip. Version 4.7.9 does not work.
>>>> Upgrading to 4.10 solves the problem. The build docs need updating if
>>>> the minimum sip version has changed.
>>> Updated minimal SIP version in installation guide to 4.8 (which might
>>> work too). Works with 4.9 here.
>> I tried the newest sip 4.10 and PyQt 4.7 last night. PyQt 4.7 seemed to be disliked by cmake, which dropped python support.
>> Perhaps someone else is willing to see if this new combo works for them?
> It works on Ubuntu. I can't get QGIS to compile on my mac using cmake
> or xcode since I upgraded to Snow Leopard...
Note that the minimum SIP/PyQt version is affected by the Qt version used. ie to use the new Qt 4.6 (fuly) you need at least SIP 4.10 and PyQt 4.7.
Gary - what compile problems are you having on Snow? I'm using Qt 4.5 Carbon right now, but the Xcode project should work with 4.6 (John's tested that a bit). I haven't tried Qt Cocoa yet, but will start soon now that Qgis 1.4 is out. I don't use the cmake build any more, except to occassionally test that it works.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
