[Qgis-developer] OSX Xcode python compilation update, small config change
John C. Tull john.tull at wildnevada.org
Sat Jan 16 18:48:14 EST 2010
If you have an older template, do you have to update it to get the speedup in the build, or will it pick up these improvements anyway?
On Jan 16, 2010, at 2:29 PM, William Kyngesburye wrote:
> (meant to go to list?)
> Note that part of the speedup is from Martin and applies to cmake build (and he said something about an option that does parallel compilation in cmake, like Xcode does).
> On Jan 16, 2010, at 3:38 PM, John C. Tull wrote:
>> Great work everyone! Might be time to quit cmake builds, except for bleeding edge updates between William's xcode project fixes.
>> On Jan 16, 2010, at 11:24 AM, William Kyngesburye wrote:
>>> The xcode project is updated to handle the new python module compilation (thanks Martin!).  It compiles faster - from the new compilation process from Martin, and now the sources are compiled by Xcode instead of by the old python script so they can take advantage of Xcode's multithreading.
>>> A new addition to the Xcode configuration - PYQT_SIP_DIR and PYQT_SIP_FLAGS.  These are set by default to SIP+PyQt (Carbon) installed for the system Python as described in the INSTALL doc.  They may need to be adjusted (manually) for other configurations.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
