[Qgis-developer] Xcode build problems
William Kyngesburye
woklist at kyngchaos.com
Sat Jan 16 21:16:55 EST 2010
On Jan 16, 2010, at 7:43 PM, Gary Sherman wrote:
>> So, python qgis compiled? What error are you getting?
> QGIS compiles and runs, this shows up in the popup:
> Couldn't load PyQt4.
> Python support will be disabled.
> getvalue() did not return a string
> Python version:
> 2.5.1 (r251:54869, Apr 18 2007, 22:08:04)
> [GCC 4.0.1 (Apple Computer, Inc. build 5367)]
> Python path:
> ['/Users/gsherman/development/qgis_trunk_git/mac/xcode/build/snow/Release/Qgis.app/Contents/MacOS/../Resources/python',
> '/Users/gsherman/.qgis//python',
> '/Users/gsherman/.qgis//python/plugins',
> '/Users/gsherman/development/qgis_trunk_git/mac/xcode/build/snow/Release/Qgis.app/Contents/MacOS/../Resources/python/plugins',
> '/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-packages',
> '/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5',
I assume you compiled PyQt for the python.org Python 2.5, and then configured Qgis for the same? It should work theoretically, though I haven't tried that combination (the default configuration for the Xcode project is to use the system python).
Or as John pointed out, maybe your old configuration file for Qgis is still configured for the python.org Python but you intended to use the system python?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
