[Qgis-developer] More python renderer V2 plugin questions!!
Chris Crook ccrook at linz.govt.nz
Wed Jan 20 19:01:10 EST 2010
Hi
I've got a python renderer almost working, apart from a fatal crash when I try to apply it to a layer!  Hopefully I'll get that sorted soon :-)
Can I configure the renderer so that it is not presented as an option for line and polygon layers.  It is only appropriate for point layers, so ideally it shouldn't show in the dialog for other layer types.  I guess the least I can do is show an error dialog box if it is selected for other types?
Thanks
Chris
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100121/19412210/attachment.html
