[Qgis-developer] Belge 1972 / Belgian Lambert 72 (31370) - towgs84
parameters
Thibaut Gheysen
gheysen.t at gmail.com
Fri Jan 22 03:34:15 EST 2010
I have a problem in QGIS 1.4.0 when I reproject a gpx file into Belgian
lambert 72 coordinate system : the waypoints are not correctly placed on the
map (see the image
http://www.fsagx.ac.be/gf/outilslogiciels/Garbel/proj4.jpg, correct
positions are in red). In QGIS, the towgs84 parameters are
'+towgs84=106.869,-52.2978,103.724,-0.33657,0.456955,-1.84218,1' for this
coordinate system. According to a discussion on the proj.4 mailing list (
http://lists.maptools.org/pipermail/proj/2010-January/005016.html), the
correct parameters seems to be
'+towgs84=-99.059,53.322,-112.486,0.419,-0.830,1.885,-1' (accurate to a
meter) or
'+towgs84=-106.8686,52.2978,-103.7329,-0.3366,0.457,-1.8422,-1.2747'
(accurate to 20 cm).
Best regards,
Thibaut.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100122/57d66e5c/attachment.html
