[Qgis-developer] Zip Layers Plugin
Giovanni Manghi
giovanni.manghi at gmail.com
Fri Jan 22 06:02:17 EST 2010
Olá Luiz,
nice works as always.
Just a few notes:
a) if the vector is a shape and the .prj file is not available then the
plugin throws a pyhton error "OSError: [Errno 2] No such file or
directory: '/home/gio/Desktop/penela/mat_base/cart_2/vector.prj'
b) once a zip is created the button "create zips" become not available
to be be clicked again
c) under linux (ubuntu), in the UI, the "description layer" window is a
little higher than the "vector layers" window. It would be good also to
let the user resize the UI at least horizontally to improve the reading
of the infos in the "description layer" window.
thanks!
-- Giovanni --
On Fri, 2010-01-22 at 01:13 -0200, Luiz Motta wrote:
> Hi all,
> I post the plugin "Zip Layers", site of User-Contributed Python Plug,
> this plugin create zipfiles from
> layers of Layers/Legend in QGIS.
> Each zipfile is a shapefile of one layer.
> The layer is not necessary be in shapefile format.
> I tested with a spatialite source, where, the BLOB field was saved how
> text field.
> I believe if have the field not supported by shapefile provider(OGR),
> this will be created how text field.
> I would like testing the datetime field from layer in Postgresql/Postgis.
> Please, someone can test this case.
> Best regards,
> Luiz Motta
> Qgis-developer mailing list
